Evening all,
its been a while since I last ventured into the world of Arduino so I’m looking for some help.
I am using the following code to control a stepper motor via mqtt. What I want to do is control 2 motors individually from the same sketch and add the option of controlling the motors from physical buttons. I will be running this from a nodemcu i think.
Any guidance will be greatly received.
#include <SimpleTimer.h> //https://github.com/marcelloromani/Arduino-SimpleTimer/tree/master/SimpleTimer
#include <ESP8266WiFi.h> //if you get an error here you need to install the ESP8266 board manager
#include <ESP8266mDNS.h> //if you get an error here you need to install the ESP8266 board manager
#include <PubSubClient.h> //https://github.com/knolleary/pubsubclient
#include <ArduinoOTA.h> //https://github.com/esp8266/Arduino/tree/master/libraries/ArduinoOTA
#include <AH_EasyDriver.h> //http://www.alhin.de/arduino/downloads/AH_EasyDriver_20120512.zip
#define USER_SSID "BTH"
#define USER_PASSWORD "RP3"
#define USER_MQTT_SERVER "192.168.1.114"
#define USER_MQTT_PORT 1883
#define USER_MQTT_USERNAME "mqtt"
#define USER_MQTT_PASSWORD "mqttpassword"
#define USER_MQTT_CLIENT_NAME "ARDTEST" // Used to define MQTT topics, MQTT Client ID, and ArduinoOTA
#define STEPPER_SPEED 45 //Defines the speed in RPM for your stepper motor
#define STEPPER_STEPS_PER_REV 1028 //Defines the number of pulses that is required for the stepper to rotate 360 degrees
#define STEPPER_MICROSTEPPING 0 //Defines microstepping 0 = no microstepping, 1 = 1/2 stepping, 2 = 1/4 stepping
#define DRIVER_INVERTED_SLEEP 1 //Defines sleep while pin high. If your motor will not rotate freely when on boot, comment this line out.
#define STEPS_TO_CLOSE 20 //Defines the number of steps needed to open or close fully
#define STEPPER_DIR_PIN D6
#define STEPPER_STEP_PIN D7
#define STEPPER_SLEEP_PIN D5
#define STEPPER_MICROSTEP_1_PIN 14
#define STEPPER_MICROSTEP_2_PIN 12
WiFiClient espClient;
PubSubClient client(espClient);
SimpleTimer timer;
AH_EasyDriver shadeStepper(STEPPER_STEPS_PER_REV, STEPPER_DIR_PIN ,STEPPER_STEP_PIN,STEPPER_MICROSTEP_1_PIN,STEPPER_MICROSTEP_2_PIN,STEPPER_SLEEP_PIN);
//Global Variables
bool boot = true;
int currentPosition = 0;
int newPosition = 0;
char positionPublish[50];
bool moving = false;
char charPayload[50];
const char* ssid = USER_SSID ;
const char* password = USER_PASSWORD ;
const char* mqtt_server = USER_MQTT_SERVER ;
const int mqtt_port = USER_MQTT_PORT ;
const char *mqtt_user = USER_MQTT_USERNAME ;
const char *mqtt_pass = USER_MQTT_PASSWORD ;
const char *mqtt_client_name = USER_MQTT_CLIENT_NAME ;
//Functions
void setup_wifi() {
// We start by connecting to a WiFi network
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
void reconnect()
int retries = 0;
while (!client.connected()) {
if(retries < 150)
Serial.print("Attempting MQTT connection...");
if (client.connect(mqtt_client_name, mqtt_user, mqtt_pass))
Serial.println("connected");
if(boot == false)
client.publish(USER_MQTT_CLIENT_NAME"/checkIn","Reconnected");
if(boot == true)
client.publish(USER_MQTT_CLIENT_NAME"/checkIn","Rebooted");
// ... and resubscribe
client.subscribe(USER_MQTT_CLIENT_NAME"/blindsCommand");
client.subscribe(USER_MQTT_CLIENT_NAME"/positionCommand");
else
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
retries++;
// Wait 5 seconds before retrying
delay(5000);
if(retries > 149)
ESP.restart();
void callback(char* topic, byte* payload, unsigned int length)
Serial.print("Message arrived [");
String newTopic = topic;
Serial.print(topic);
Serial.print("] ");
payload[length] = '\0';
String newPayload = String((char *)payload);
int intPayload = newPayload.toInt();
Serial.println(newPayload);
Serial.println();
newPayload.toCharArray(charPayload, newPayload.length() + 1);
if (newTopic == USER_MQTT_CLIENT_NAME"/blindsCommand")
if (newPayload == "OPEN")
client.publish(USER_MQTT_CLIENT_NAME"/positionCommand", "0", true);
else if (newPayload == "CLOSE")
int stepsToClose = STEPS_TO_CLOSE;
String temp_str = String(stepsToClose);
temp_str.toCharArray(charPayload, temp_str.length() + 1);
client.publish(USER_MQTT_CLIENT_NAME"/positionCommand", charPayload, true);
else if (newPayload == "STOP")
String temp_str = String(currentPosition);
temp_str.toCharArray(positionPublish, temp_str.length() + 1);
client.publish(USER_MQTT_CLIENT_NAME"/positionCommand", positionPublish, true);
if (newTopic == USER_MQTT_CLIENT_NAME"/positionCommand")
if(boot == true)
newPosition = intPayload;
currentPosition = intPayload;
boot = false;
if(boot == false)
void processStepper()
if (newPosition > currentPosition)
#if DRIVER_INVERTED_SLEEP == 1
shadeStepper.sleepON();
#endif
#if DRIVER_INVERTED_SLEEP == 0
shadeStepper.sleepOFF();
#endif
shadeStepper.move(80, FORWARD);
currentPosition++;
moving = true;
if (newPosition < currentPosition)
#endif
#endif
shadeStepper.move(80, BACKWARD);
currentPosition--;
moving = true;
if (newPosition == currentPosition && moving == true)
#endif
#endif
client.publish(USER_MQTT_CLIENT_NAME"/positionState", positionPublish);
moving = false;
Serial.println(currentPosition);
Serial.println(newPosition);
void checkIn()
client.publish(USER_MQTT_CLIENT_NAME"/checkIn","OK");
//Run once setup
void setup() {
Serial.begin(115200);
shadeStepper.setMicrostepping(STEPPER_MICROSTEPPING); // 0 -> Full Step
shadeStepper.setSpeedRPM(STEPPER_SPEED); // set speed in RPM, rotations per minute
#endif
#endif
WiFi.mode(WIFI_STA);
setup_wifi();
client.setServer(mqtt_server, mqtt_port);
client.setCallback(callback);
ArduinoOTA.setHostname(USER_MQTT_CLIENT_NAME);
ArduinoOTA.begin();
delay(10);
timer.setInterval(((1 << STEPPER_MICROSTEPPING)*5800)/STEPPER_SPEED, processStepper);
timer.setInterval(90000, checkIn);
void loop()
if (!client.connected())
reconnect();
client.loop();
ArduinoOTA.handle();
timer.run();
/***************** START USER CONFIG SECTION *********************************/
#define USER_SSID "BTHub6-CFR5"
#define USER_PASSWORD "RP3wpV9DcNMH"
#define USER_MQTT_PASSWORD "mqttpw"
const int Openbutton = D1;
const int Closebutton = D2;
const int Stopbutton = D3;
int buttonState = 0;
/***************** END USER CONFIG SECTION *********************************/
SimpleTimer timer;
AH_EasyDriver shadeStepper(STEPPER_STEPS_PER_REV, STEPPER_DIR_PIN , STEPPER_STEP_PIN, STEPPER_MICROSTEP_1_PIN, STEPPER_MICROSTEP_2_PIN, STEPPER_SLEEP_PIN);
//Global Variables
bool boot = true;
//Functions
void setup_wifi() {
Serial.println();
delay(500);
Serial.print(".");
Serial.println("");
void reconnect()
int retries = 0;
if (retries < 150)
if (boot == false)
client.publish(USER_MQTT_CLIENT_NAME"/checkIn", "Reconnected");
if (boot == true)
client.publish(USER_MQTT_CLIENT_NAME"/checkIn", "Rebooted");
else
retries++;
delay(5000);
if (retries > 149)
ESP.restart();
Serial.print("] ");
Serial.println();
if (boot == true)
boot = false;
if (boot == false)
#endif
#endif
currentPosition++;
moving = true;
#endif
#endif
currentPosition--;
moving = true;
#endif
#endif
moving = false;
void checkIn()
client.publish(USER_MQTT_CLIENT_NAME"/checkIn", "OK");
//Run once setup
void setup() {
#endif
#endif
setup_wifi();
ArduinoOTA.begin();
delay(10);
timer.setInterval(((1 << STEPPER_MICROSTEPPING) * 5800) / STEPPER_SPEED, processStepper);
pinMode(Openbutton, INPUT);
pinMode(Closebutton, INPUT);
pinMode(Stopbutton, INPUT);
void loop()
reconnect();
client.loop();
timer.run();
buttonState = digitalRead(Openbutton);
if (buttonState == HIGH) {
Serial.println ("Open");
buttonState = digitalRead(Closebutton);
Serial.println ("Close");
buttonState = digitalRead(Stopbutton);
Serial.println ("Stop");
Above is my attempt to add the code for the switches. Does it look anywhere near right?
Thanks again
