Mqtt as a test in the action
using this input_boolean
input_boolean:
  shop_lock:
    name: 'Shop is Lock'
There are a lot of examples of using MQTT as a trigger. I have a button that action is “single”, “double”, and “long”.
This one will turn on the boolean.
automation:
  - alias: Shop Lock From Click
    id: Shop Lock From Click
    - platform: mqtt
      topic: "zigbee2mqtt/0x00xxxxx"
    condition:
      - condition: template
        value_template: "{{ trigger.payload_json['action'] == 'single' }}"
      entity_id: input_boolean.shop_lock
What I would like is some sort of combination of single and double
For example, a ‘single’ a ‘double’ then a ‘single’
How do you get it to read mqtt in a wait_template?
I am guessing I need a different way, since I guessing the json is loaded off of the first trigger.
automation:
    - platform: mqtt
      topic: "zigbee2mqtt/0x00124xxxxxx"
    condition:
    - wait_template: "{{ trigger.payload_json['action'] == 'double' }}"
      timeout:
        seconds: 5
      continue_on_timeout: false
    - wait_template: "{{ trigger.payload_json['action'] == 'single' }}"
      timeout:
        seconds: 5
Use wait for trigger instead of wait template.
That got me close. The trigger condition is satisfied with and press. I am not sure of the correct syntax for not only a trigger of an MQTT payload but only if it is a double click.
This was my last try …
input_boolean:
  shop_lock:
automation:
  - alias: Shop Unlock From Click
    id: Shop Unlock From Click
    - platform: mqtt
      topic: "zigbee2mqtt/0x00124b0025143172"
    condition:
    - wait_for_trigger:
      - platform: mqtt
        value_template: "{{ trigger.payload_json['action'] == 'double' }}"
      timeout:
        seconds: 5
    - service: input_boolean.turn_off
  - alias: Shop lock From Click
    - platform: mqtt
    condition:
        value_template: "{{ trigger.payload_json['action'] == 'long' }}"
In the Discord Automation channel, @TheFes gave me the fix.
Anyone running across this thread, here is the working yaml …
automation:
  • alias: Shop Unlock From Click
    • platform: mqtt
      topic: “zigbee2mqtt/0x00124b00xxxxx”
      value_template: “{{ value_json.action }}”
      payload: “single”
      condition: []
    • wait_for_trigger:
      • platform: mqtt
        topic: “zigbee2mqtt/0x00124bxxxxx”
        payload: “double”
        timeout: “00:00:05”
    • wait_for_trigger:
      • platform: mqtt
        topic: “zigbee2mqtt/0x00124bxxxxxx”
        payload: “single”
        timeout: “00:00:05”
    • service: input_boolean.turn_off
