MQTT audio discovery help
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
mqtt:
  broker: 192.168.0.21
  discovery: true
  discovery_prefix: homeassistant
In HomeAssistant GUI under dev tools/MQTT I can see loads of devices
Message 214 received on shellies/shellyswitch25-E66DB8/overtemperature at 19:57:
0
QoS: 0 - Retain: false
Message 213 received on shellies/shellyswitch25-E66DB8/temperature_f at 19:57:
137.61
Message 212 received on shellies/shellyswitch25-E66DB8/temperature at 19:57:
58.67
Message 211 received on shellies/shellyswitch25-E66DB8/input_event/1 at 19:57:
    "event": "",
    "event_cnt": 0
Message 210 received on shellies/shellyswitch25-E66DB8/input/1 at 19:57:
1
Message 209 received on shellies/shellyswitch25-E66DB8/input_event/0 at 19:57:
    "event": "",
    "event_cnt": 0
Message 208 received on shellies/shellyswitch25-E66DB8/input/0 at 19:57:
1
Message 207 received on shellies/shellyswitch25-E66DB8/relay/1/energy at 19:57:
1049
Message 206 received on shellies/shellyswitch25-E66DB8/relay/1/power at 19:57:
0
Message 205 received on shellies/shellyswitch25-E66DB8/relay/1 at 19:57:
off
Message 204 received on shellies/shellyswitch25-E66DB8/relay/0/energy at 19:57:
429
Message 203 received on shellies/shellyswitch25-E66DB8/relay/0/power at 19:57:
0
Message 202 received on shellies/shellyswitch25-E66DB8/relay/0 at 19:57:
off
Message 201 received on shellies/shellyswitch25-0082FD/overtemperature at 19:57:
0
Message 200 received on shellies/shellyswitch25-0082FD/temperature_f at 19:57:
153.05
Message 199 received on shellies/shellyswitch25-0082FD/temperature at 19:57:
67.25
Message 198 received on shellies/shellyswitch25-0082FD/input_event/1 at 19:57:
    "event": "",
    "event_cnt": 0
Message 197 received on shellies/shellyswitch25-0082FD/input/1 at 19:57:
0
Message 196 received on shellies/shellyswitch25-0082FD/input_event/0 at 19:57:
    "event": "",
    "event_cnt": 0
Message 195 received on shellies/shellyswitch25-0082FD/input/0 at 19:57:
0
Message 194 received on shellies/shellyswitch25-0082FD/relay/1/energy at 19:57:
23070
Message 193 received on shellies/shellyswitch25-0082FD/relay/1/power at 19:57:
38.38
Message 192 received on shellies/shellyswitch25-0082FD/relay/1 at 19:57:
on
Message 191 received on shellies/shellyswitch25-0082FD/relay/0/energy at 19:57:
5140
Message 190 received on shellies/shellyswitch25-0082FD/relay/0/power at 19:57:
0
Message 189 received on shellies/shellyswitch25-0082FD/relay/0 at 19:57:
off
Message 188 received on shellies/shelly1-2278B2-11/input_event/0 at 19:57:
    "event": "",
    "event_cnt": 0
Message 187 received on shellies/shelly1-2278B2-11/input/0 at 19:57:
0
Message 186 received on shellies/shelly1-2278B2-11/relay/0 at 19:57:
off
Message 185 received on shellies/shelly1-227CA3/input_event/0 at 19:57:
    "event": "",
    "event_cnt": 0
Message 184 received on shellies/shelly1-227CA3/input/0 at 19:57:
0
MQTT explorer can see loads of devices
But nothing is discovery in HomeAssistant. I have reset docker, its using the same network as the host? I have re-installed mosquito
The mosquitto addon is configured through the user interface, delete the mqtt yaml config and follow the addon documentation.
Also discovery requires your devices to publish to the homeassistant discovery topic.
Shelly’s don’t do this. You will have to manually configure them in yaml.
Tasmota does. Just setOption19 = 1
If you want your shellies to be auto-discovered, run the shellies discovery script :
For your zigbee2mqtt devices : in the zigbee2mqtt configuration.yaml set homeassistant: true
And as tom_l said : for tasmota, enter setoption19 1 in the tasmota console.
took a night away from the keyboard. Cleared the lot and started again and its worked this time.
Thanks for the speedy help.
