RedChili
(Reinhard Weber)
October 26, 2023, 10:07am
1
I’m trying to create a auto-config via MQTT. I’m good on the sensor side (read only from device) but I’m struggling with the configuration of number inputs, that should trigger a publish the set value to a command topic. So far I have:
"name": "Output Power Limit",
"cmd_t": "iot/73bkTV/{{ device_id }}/properties",
"cmd_tpl": "{'properties': {'outputLimit': value}",
"stat_t": "~outputLimit",
"uniq_id": "{{ device_id }}-outputLimit",
"dev_cla": "power",
"unit_of_meas": "W",
"max": 800,
"min": 0,
"step": 1,
"dev": {...},
"~": "solarflow-hub/{{ device_id }}/telemetry/"
Upon change of the number input this should publish a message to the “cmd_t” with a JSON payload (cmd_tpl?) that looks like this:
{ "properties": {"outputLimit": <value of number input>} }
How can I do this? Any ideas?
Thanks!
123
(Taras)
October 26, 2023, 1:08pm
2
Post the entire script that you are using to publish this Discovery payload.
RedChili
(Reinhard Weber)
October 30, 2023, 11:20am
3
template.json
"cmd_t": "iot/73bkTV/{{ device_id }}/properties/write",
"cmd_tpl": "{\"properties\": {\"outputLimit\": value}}",
"dev_cla": "power",
"max": 800,
"min": 0,
"step": 1,
"dev": {
"identifiers": ["{{ device_id }}"],
"manufacturer": "Zendure",
"model": "Solarflow",
"name": "Solarflow Hub",
"sw_version": "{{ fw_version }}"
Code to publish:
def pushHomeassistantConfig(self):
hatemplates = [f for f in pathlib.Path().glob("homeassistant/*.json")]
environment = Environment(loader=FileSystemLoader("homeassistant/"), undefined=DebugUndefined)
for hatemplate in hatemplates:
template = environment.get_template(hatemplate.name)
hacfg = template.render(device_id=self.deviceId, fw_version=self.fwVersion)
cfg_type = hatemplate.name.split(".")[0]
cfg_name = hatemplate.name.split(".")[1]
self.client.publish(f'homeassistant/{cfg_type}/solarflow-hub-{self.deviceId}-{cfg_name}/config',hacfg)
