MQTT AutoDiscovery add registry configuration to switch
On esp8266, i would like to push more data on MQTT discovery , my code work fine, but i am not able to add these key :
'cns':                 'connections',
'ids':                 'identifiers',
'name':                'name',
'mf':                  'manufacturer',
'mdl':                 'model',
'sw':                  'sw_version',
Do not work because of kind “switch” ?
Can i add more data like url ?
Thanks,
Best regards.
Can’t you put your misc things in the attributes?
'json_attr_t':         'json_attributes_topic',
(string)(Optional)
The MQTT topic subscribed to receive a JSON dictionary payload and then set as sensor attributes. Usage example can be found in [MQTT sensor](https://www.home-assistant.io/integrations/sensor.mqtt/#json-attributes-topic-configuration) documentation.
So I’m guessing you can fill in the attributes topic, then publish all random attributes to said topic.
I give up , because, as i understood, i needed to make a json template configuration file , and if this file does not exist, mqtt discovery failed with unknow attribut .
I wait for more understanding explanation about that.
Best regards.
I assume because you said ESP8266, you’re writing your own code.
You will have to create a json message for that state topic.
If you’re writing your own code, there are libraries to package data into json for you.
#include <ArduinoJson.h>
StaticJsonBuffer<500> jsonBuffer;
JsonObject& root = jsonBuffer.createObject();
root["cns"] = "connections";
root["ids"] = "identifiers";
root["name"] = "name";
root.printTo(mqtt_client);
