Hi, I have Zigbee2Mqtt , and Moes BRT-100 TRV, which is correctly connected and discovered in HA.
But, in “hvac_modes” there are too many modes (cool, fan, etc), while I need only “off” and “heat”. There is no “modes” on mqtt autodiscovery message.
If I send (manually) customized MQTT autodiscovery message , I can see no more “cool” or “fan” icons on thermostat card - so all good.
My question is - how to make it happen automatically on autodiscovery, instead of me pushing custom MQTT autodiscover message ?
I tried to “resend” additional MQTT autodiscovery message from HA ( as MQTT trigger) - but seems it is not possible to send “{{ something }}” in MQTT payload. HA is always trying to parse it, and reports an error. Tried with variables, string.replace etc, but does not work.
Hi, this got me somewhat closer after reading around for an hour
Thank you!
Is there anyway to customize in such a way that there is no hvac_mode alltogether.
I.e. my thermostat can only “heat” (can not even be turned off) so the button in the thermostat card is pointless and also it takes up extra space in the entities card when it says heating (heat)…
Would really appreciate a pointer in the right direction!
