I’m trying to get zigbee2mqtt auto discovery in Home Assistant working, and somehow it’s not working for me.
- Home Assistant runs in Docker (v 2024.8.0) on the same machine as zigbee2mqtt and mosquitto
- HA can read and publish messages to mqtt (tested via mqtt config options)
- I have several manual mqtt sensors working, with HA both reading and writing to mqtt (tested by comparing mqtt messages with HA reported values, see config below)
- zigbee2mqtt does publish to homeassistant/# (see below)
- Home Assistant settings ‘enable newly added entities’ and ‘enable polling for updates’ are toggled on.
Any idea what might be going wrong? I feel I must be missing a simple toggle somewhere…
mqtt:
- state_topic: 'smeter'
unique_id: 'smeter_consumption1'
state_class: "total_increasing"
unit_of_measurement: 'kWh'
value_template: '{{ value_json.consumption1/3600/1000 | round(1) }}'
device_class: energy
force_update: true
expire_after: 3600
unique_id: 'smeter_consumption2'
value_template: '{{ value_json.consumption2/3600/1000 | round(1) }}'
force_update: true
expire_after: 3600
unique_id: 'smeter_production1'
value_template: '{{ value_json.production1/3600/1000 | round(1) }}'
force_update: true
expire_after: 3600
unique_id: 'smeter_production2'
value_template: '{{ value_json.production2/3600/1000 | round(1) }}'
force_update: true
expire_after: 3600
- name: "itho_hru_co2"
unique_id: "itho_hru_co2"
state_topic: "itho/ithostatus"
value_template: "{{ value_json['highest-received-co2-value_ppm'] }}"
unit_of_measurement: "ppm"
device_class: carbon_dioxide
state_class: 'measurement'
device: { identifiers: ["mqtt", "nrg-itho-28ac"] }
- name: "itho_hru_exhaust_fan_actual"
unique_id: "itho_hru_exhaust_fan_actual"
unit_of_measurement: "rpm"
value_template: "{{ value_json['exhaust-fan-actual_rpm'] }}"
- name: "itho_hru_supply_fan_actual"
unique_id: "itho_hru_supply_fan_actual"
value_template: "{{ value_json['supply-fan-actual_rpm'] }}"
- name: "itho_hru_exhaust_temp"
unique_id: "itho_hru_exhaust_temp"
unit_of_measurement: "°C"
device_class: temperature
value_template: "{{ value_json['exhaust-temp_c'] }}"
- name: "itho_hru_supply_temp"
unique_id: "itho_hru_supply_temp"
value_template: "{{ value_json['supply-temp_c'] }}"
- name: "itho_hru_summer_counter"
unique_id: "itho_hru_summer_counter"
value_template: "{{ value_json['summercounter'] }}"
unit_of_measurement: "h"
device_class: duration
- name: "itho_hru_airfilter_counter"
unique_id: "itho_hru_airfilter_counter"
value_template: "{{ value_json['airfilter-counter'] }}"
binary_sensor:
- name: "itho_hru_bypass"
unique_id: "itho_hru_bypass"
value_template: "{{ value_json['bypass-position'] }}"
payload_off: 0
payload_on: 1
device_class: opening
- name: "itho_hru_summer"
unique_id: "itho_hru_summer"
value_template: "{{ value_json['summerday_kmin'] }}"
payload_off: 0
payload_on: 1
device_class: light
fan:
- name: "itho_hru_fan"
device:
model: ITHO Wifi Add-on
#availability_topic: itho/state
unique_id: itho_hru_fan
state_topic: itho/lwt
payload_on: "online"
payload_off: "offline"
#state_value_template: '{% if value == "online" %}ON{% else %}OFF{% endif %}'
# json_attributes_topic: itho/ithostatus
command_topic: "itho/cmd"
preset_mode_command_template: "{ vremote: '{{ value }}'}"
preset_mode_command_topic: "itho/cmd"
preset_mode_state_topic: "itho/ithostatus"
preset_mode_value_template: >
{% set am = value_json['actual-mode'] | int %}
{% if am == 1 %}
low
{% elif am == 2 %}
medium
{% elif am == 3 %}
high
{% elif am == 13 %}
timer
{% elif am == 24 %}
auto
{% elif am == 25 %}
autonight
{% else %}
{{ am }}
{% endif %}
preset_modes:
- "low"
- "medium"
- "high"
- "auto"
- "autonight"
- "timer1"
- "timer2"
- "timer3"
homeassistant/switch/0x00158d0003xxxxxx/switch/config {"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"command_topic":"zigbee2mqtt/0x00158d0003xxxxxx/set","device":{"identifiers":["zigbee2mqtt_0x00158d0003xxxxxx"],"manufacturer":"Innr","model":"Smart plug (SP 120)","name":"0x00158d0003xxxxxx","sw_version":"2.0","via_device":"zigbee2mqtt_bridge_0x00212effff054066"},"json_attributes_topic":"zigbee2mqtt/0x00158d0003xxxxxx","name":null,"object_id":"0x00158d0003xxxxxx","origin":{"name":"Zigbee2MQTT","sw":"1.39.1","url":"https://www.zigbee2mqtt.io"},"payload_off":"OFF","payload_on":"ON","state_topic":"zigbee2mqtt/0x00158d0003xxxxxx","unique_id":"0x00158d0003xxxxxx_switch_zigbee2mqtt","value_template":"{{ value_json.state }}"}
