MQTT autodiscovery with nested topics containing /
I have read the docu from here, but cannot find an answer to my topic.
I have a battery which consists of battery packs and packs consists of cells. I want to store the cell voltages in home-assistant. Voltages are send out with:
BatteryPack/%packnumer/%cellnumber, so p.ex.
BatteryPack/1/4 = 5.839
I cannot get it running with the packnumber and cellnumber separated by “/”.
I have written this code to test the functionality:
import paho.mqtt.client as paho
import time
import random
broker = "192.168.103.44"
port = 1883
#   homeassistant/sensor/ESP_Easy_Pufferspeicher/Puffer_unten/config
#   { 	"name": "Puffer unten temperature", 	"unique_id": "Puffer_unten_temperature", 	"object_id": "Puffer_unten_temperature", 	"icon": "mdi:thermometer-lines", 	"state_topic": "ESP_Easy_Pufferspeicher/Puffer_unten/temperature", 	"unit_of_measurement": "°C",     "retain": "true", 	"device": { 		"name": "ESP_Easy_Pufferspeicher", 		"manufacturer": "Bard", 		"model": "ESP", 		"identifiers": "ESP-Eigenbau" 	} }
#   BatteryPack/1/0
if __name__ == '__main__':
    client = paho.Client("control")  # create client object
    client.connect(broker, port)  # establish connection
    packnumber = 6
    cellnumber = 12
    config_send = 1
    data_send = 1
    if config_send:
        for pack in range(0, packnumber-1):
            print("Send out config")
            for cell in range(0, cellnumber-1):
                topic = "homeassistant/sensor/BatteryPack/" + str(pack)   +  "/config"
                name = "BMW_Battery_Pack_"+ str(pack) + "_Cell_" + str(cell)
                state_topic = "BatteryPack/" + str(pack)
                message = '{ 	"name": "'+ name + '", 	"unique_id": "'+ name + '", "object_id": "' + name + '", 	"icon": "mdi:thermometer-lines", 	"state_topic": "' + state_topic + '", 	"unit_of_measurement": "mV",     "retain": "true", 	"device": { 		"name": "BMW Akku Jonas2", 		"manufacturer": "Bard", 		"model": "unknown", 		"identifiers": "Jonas-Eigenbau" 	} }'
                try:
                    ret = client.publish(topic, message)  # publish
                    print(topic, message)
                except Exception as e:
                    print(e)
                    pass
                time.sleep(0.1)
    print("Send out data")
            message = round(random.random()*500,1)
            try:
                print(e)
                pass
            time.sleep(0.3)
This code works, but does not contain the functionality as explained above, I only have one level (battery packs) here.
This is the intended code, but not working:
import time
import random
port = 1883
#   BatteryPack/1/0
    packnumber = 6
    cellnumber = 12
    config_send = 1
    data_send = 1
    if config_send:
                topic = "homeassistant/sensor/BatteryPack/" + str(pack)  + str(cell)   +  "/config"
                state_topic = "BatteryPack/" + str(pack) + "/" + str(cell)
                try:
                    print(e)
                    pass
                time.sleep(0.1)
            try:
                print(e)
                pass
            time.sleep(0.3)
