MQTT Automations - Parse JSON
I have a stream of events feeding in to MQTT. I want to set up an automation to run when a specific event is received. A sample of the JSON is below
    "time": "2020-06-23 10:22:54",
    "model": "Smoke detector GS 558",
    "id": 18504,
    "unit": 0,
    "learn": 0,
    "code": "f90900"
I can put the payload in the automation trigger but the time will change every time so won’t match the received payload. Is there any way I can tell the trigger just to inspect a specific field?
trigger.json.model for example.
I managed to find another post that did something with conditions:
{{ trigger.payload_json['id'] == 18504 }}
I can’t find any info on trigger.json.model hower?
Thanks!
if trigger.json is
    "id": 18504,
    "unit": 0,
    "learn": 0,
    "code": "f90900"
then
trigger.json.model is
I have the same smoke detector GS558 streamed to MQTT by RTL_433.
If I do understand correctly there isn’t any Boolean flag or similar changing when heat/smoke is reported but simply the sensor send that payload and only value changing is time?
Is it for this reason that @bleep-io you want to create a trigger (for an automation I guess) when payload is received?
…just trying to understand how to manage smoke alarm with my sensor
It’s actually not that smoke alarm but a doorbell. For some reason it maps to the above event in RTL_433.
Whenever the doorbell button is pressed I get that event.
Can I ask how you run RTL_433? I have it just running in a terminal windows but if I restart my server I have to manually start it again.
I use this:
Works very well on RPI3
