My MQTT setup through HA seems to have broken overnight after working quite well for months.
Relevant info:
Mosquitto broker Add-on [version: 5.1]
Config:logins: [] anonymous: false customize: active: false folder: mosquitto certfile: fullchain.pem keyfile: privkey.pem require_certificate: false
MQTT Integration (Can’t connect either)
Config:
The user “mqtt_device” is set up in the HA users for all the MQTT devices I have.
HA version 0.118.4
OS version HassOS 4.17
Raspberry Pi 3B+
Here’s a sample of the logs from Mosquitto:
[15:58:29] INFO: Setup mosquitto configuration [15:58:29] INFO: No local user available [15:58:30] INFO: Initialize Hass.io Add-on services [15:58:31] INFO: Initialize Home Assistant discovery [15:58:31] INFO: Start Mosquitto daemon 1607032711: mosquitto version 1.6.3 starting 1607032711: Config loaded from /etc/mosquitto.conf. 1607032711: Loading plugin: /usr/share/mosquitto/auth-plug.so 1607032711: |-- *** auth-plug: startup 1607032711: ├── Username/password checking enabled. 1607032711: ├── TLS-PSK checking enabled. 1607032711: └── Extended authentication not enabled. 1607032711: Opening ipv4 listen socket on port 1883. 1607032711: Opening ipv6 listen socket on port 1883. 1607032711: Opening websockets listen socket on port 1884. 1607032711: Opening ipv4 listen socket on port 8883. 1607032711: Opening ipv6 listen socket on port 8883. 1607032711: Opening websockets listen socket on port 8884. 1607032711: Warning: Mosquitto should not be run as root/administrator. 1607032720: New connection from 192.168.69.60 on port 1883. [ERROR] Auth error with mqtt_device 1607032722: Socket error on client <unknown>, disconnecting. 1607032722: New connection from 192.168.69.62 on port 1883. 1607032722: Socket error on client <unknown>, disconnecting.
Here’s an example log from a device side (MagicHome LED light controller flashed with Tasmota):
00:00:00 CFG: Loaded from flash at F8, Count 212 00:00:00 QPC: Count 1 00:00:00 Project tasmota bookshelf_leds Version 9.1.0(tasmota)-2_7_4_5 00:00:00 WIF: Connecting to AP1 [MY_IOT_NETWORK] Channel 11 BSSId 76:83:C2:9C:05:42 in mode 11N as bookshelf_leds-7515... 00:00:01 WIF: Connected 00:00:02 HTP: Web server active on bookshelf_leds-7515 with IP address 192.168.69.60 00:00:03 MQT: Attempting connection... 00:00:03 MQT: Connect failed to 192.168.69.34:1883, rc 5. Retry in 10 sec 00:00:06 QPC: Reset 00:00:14 MQT: Attempting connection... 00:00:14 MQT: Connect failed to 192.168.69.34:1883, rc 5. Retry in 10 sec
The IP/Port
192.168.69.34:1883
referenced here is my MQTT broker/HA instance.
I swear I’ve checked username/password like 5 times on each device too.
Also I don’t have any lines in confuration.yaml having to do with MQTT. I’ve seen some other post with similar issues, but there didn’t seem to be a resolution.
Thanks!
