Mqtt broker constantly changing users
Hello folks,
Stubborn Newbie here. My Mqtt and zigbee2mqtt are not properly connected.
When I was setting up Mosquito I created user, but later I decided to use default configuration on MQTT.
FACTS:
When MQTT works Zigbee2MQTT doesn’t and vice versa.
MQTT LOG:
2024-08-08 20:22:58: Client 0Dmri95yMrmlJc1NZSCppd closed its connection.
2024-08-08 20:23:29: New connection from 172.30.32.1:33275 on port 1883.
2024-08-08 20:23:29: New client connected from 172.30.32.1:33275 as 5xRI785YzxqUn8HSBr0LUA (p2, c1, k60, u’MYUSER’).
2024-08-08 20:24:07: Client mqttjs_13755899 disconnected.
2024-08-08 20:28:21: Saving in-memory database to /data//mosquitto.db.
2024-08-08 20:28:55: New connection from 172.30.33.1:35222 on port 1883.
2024-08-08 20:28:55: New client connected from 172.30.33.1:35222 as mqttjs_a654368c (p2, c1, k60, u’addons’).
2024-08-08 20:29:19: Client mqttjs_a654368c disconnected.
2024-08-08 20:29:43: New connection from 172.30.33.1:35482 on port 1883.
2024-08-08 20:29:43: New client connected from 172.30.33.1:35482 as mqttjs_881d1eaf (p2, c1, k60, u’addons’).
2024-08-08 20:30:21: Client mqttjs_881d1eaf disconnected.
2024-08-08 20:30:45: New connection from 172.30.33.1:44124 on port 1883.
2024-08-08 20:30:45: New client connected from 172.30.33.1:44124 as mqttjs_fb690e96 (p2, c1, k60, u’addons’).
2024-08-08 20:31:22: Client mqttjs_fb690e96 disconnected.
2024-08-08 20:31:46: New connection from 172.30.33.1:59818 on port 1883.
2024-08-08 20:31:46: New client connected from 172.30.33.1:59818 as mqttjs_ceb24911 (p2, c1, k60, u’addons’).
2024-08-08 20:33:14: Client mqttjs_ceb24911 disconnected.
2024-08-08 20:33:38: New connection from 172.30.33.1:34288 on port 1883.
2024-08-08 20:33:38: New client connected from 172.30.33.1:34288 as mqttjs_94ff0408 (p2, c1, k60, u’addons’).
2024-08-08 20:35:06: Client mqttjs_94ff0408 disconnected.
2024-08-08 20:35:30: New connection from 172.30.33.1:52514 on port 1883.
2024-08-08 20:35:30: New client connected from 172.30.33.1:52514 as mqttjs_ea4c7d5e (p2, c1, k60, u’addons’).
2024-08-08 20:36:58: Client mqttjs_ea4c7d5e disconnected.
2024-08-08 20:37:22: New connection from 172.30.33.1:48180 on port 1883.
2024-08-08 20:37:22: New client connected from 172.30.33.1:48180 as mqttjs_b91247f0 (p2, c1, k60, u’addons’).
2024-08-08 20:38:50: Client mqttjs_b91247f0 disconnected.
2024-08-08 20:58:22: Saving in-memory database to /data//mosquitto.db.
2024-08-08 21:10:29: Client 5xRI785YzxqUn8HSBr0LUA closed its connection.
2024-08-08 21:10:37: New connection from 172.30.33.1:33492 on port 1883.
2024-08-08 21:10:37: New client connected from 172.30.33.1:33492 as mqttjs_35710e74 (p2, c1, k60, u’addons’).
2024-08-08 21:11:00: New connection from 172.30.32.1:52505 on port 1883.
2024-08-08 21:11:00: New client connected from 172.30.32.1:52505 as 7B9GMiPqbJNlIacaBwWxhN (p2, c1, k60, u’,MYUSER’).
2024-08-08 21:11:34: Client mqttjs_35710e74 disconnected.
ZIGBEE2MQTT log:
at SerialDriver.emit (node:events:517:28)
at /app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:344:22
at Queue.execute (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20)
at SerialDriver.openSerialPort (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:106:13)
at SerialDriver.connect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:61:13)
at Ezsp.connect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:347:17)
at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:176:13)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:127:29)
at Zigbee.start (/app/lib/zigbee.ts:63:27)
[2024-08-08 21:32:05] error: zh:ezsp:uart: → Error: Error: {“sequence”:-1} after 10000ms
[2024-08-08 21:32:05] error: zh:ezsp:ezsp: Connection attempt 4 error: Error: Failure to connect
at SerialDriver.resetForReconnect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:341:19)
[2024-08-08 21:32:05] error: z2m: Error while starting zigbee-herdsman
[2024-08-08 21:32:05] error: z2m: Failed to start zigbee
[2024-08-08 21:32:05] error: z2m: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
[2024-08-08 21:32:05] error: z2m: Exiting…
[2024-08-08 21:32:05] error: z2m: Error: Failure to connect
at Ezsp.connect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:364:19)
at Controller.start (/app/lib/controller.ts:139:27)
at start (/app/index.js:154:5)
[21:37:20] INFO: Preparing to start…
[21:37:21] INFO: Socat not enabled
[21:37:26] INFO: Starting Zigbee2MQTT…
Starting Zigbee2MQTT without watchdog.
[2024-08-08 21:37:36] info: z2m: Logging to console, file (filename: log.log)
[2024-08-08 21:37:36] info: z2m: Starting Zigbee2MQTT version 1.39.1 (commit #unknown)
[2024-08-08 21:37:36] info: z2m: Starting zigbee-herdsman (0.55.3)
[2024-08-08 21:37:37] warning: zh:ezsp: Deprecated driver ‘ezsp’ currently in use, ‘ember’ will become the officially supported EmberZNet driver in next release. If using Zigbee2MQTT see Improved Ember (EZSP) driver (experimental) · Koenkk/zigbee2mqtt · Discussion #21462 · GitHub
[2024-08-08 21:37:47] error: zh:ezsp:uart: → Error: Error: {“sequence”:-1} after 10000ms
[2024-08-08 21:37:47] error: zh:ezsp:ezsp: Connection attempt 1 error: Error: Failure to connect
[2024-08-08 21:38:02] error: zh:ezsp:uart: → Error: Error: {“sequence”:-1} after 10000ms
[2024-08-08 21:38:02] error: zh:ezsp:ezsp: Connection attempt 2 error: Error: Failure to connect
[2024-08-08 21:38:22] error: zh:ezsp:uart: → Error: Error: {“sequence”:-1} after 10000ms
[2024-08-08 21:38:22] error: zh:ezsp:ezsp: Connection attempt 3 error: Error: Failure to connect
[2024-08-08 21:38:47] error: zh:ezsp:uart: → Error: Error: {“sequence”:-1} after 10000ms
[2024-08-08 21:38:47] error: zh:ezsp:ezsp: Connection attempt 4 error: Error: Failure to connect
[2024-08-08 21:38:47] error: z2m: Error while starting zigbee-herdsman
[2024-08-08 21:38:47] error: z2m: Failed to start zigbee
[2024-08-08 21:38:47] error: z2m: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
[2024-08-08 21:38:47] error: z2m: Exiting…
[2024-08-08 21:38:47] error: z2m: Error: Failure to connect
Please guide me, what should I check and correct.
Hi, I am facing a similar issue in a different context.
I have two addons. One is in the host network
(having the host property set in config.yaml).
This get’s called via ingress by host 172.30.32.1
The other application has no host property set in config.yaml
It get’s called via ingress by host 172.30.33.1.
The ingress documentation tells developpers to disallow any connection from other than 172.30.32.1 . This seems to be a bit too strict.
172.30.33.1 should also be used, if host is not set.
So, if you face issues with this, check if ingress is configured in the addon and if host is not set.
In this case, the addon is too strict.
