I’ve recently flashed some devices with Tasmota with the intention of adding them via MQTT to HA. However, installing the MQTT addon, configuring it, and adding the integration for MQTT - no devices show up! I get this in the system log:
20-03-17 04:04:14 INFO (MainThread) [supervisor.auth] Auth request from core_mosquitto for mqtt
20-03-17 04:04:14 ERROR (MainThread) [supervisor.homeassistant] Error on call http://172.30.32.1:8123/api/: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
20-03-17 04:04:14 INFO (MainThread) [supervisor.auth] Home Assistant not running, check cache
20-03-17 04:04:14 WARNING (MainThread) [supervisor.auth] No cache hit for mqtt
The MQTT log is showing the devices trying to connect!
1584418768: Socket error on client <unknown>, disconnecting.
1584418778: New connection from 192.168.**.** on port 1883.
[ERROR] Auth error with mqtt
1584418778: Socket error on client <unknown>, disconnecting.
1584418779: New connection from 192.168.**.** on port 1883.
Any suggestions as to why the broker seems inaccessible? - Thanks!!
