Mqtt - broker to hassio
rtl_433 gives data and send this to a broker in Hassio
the data can be seen with MQTTexplorer in rtl_433/pi
In hassio go to MQTT configure publish in rtl_433/pi and listen to #.
Ervery things arrives in json or orther format.
dahboard gives in sensor the various subjects.
// - name: oregonTemperature
state_topic: rtl_433/pi/temperature_C
unique_id:oregon_temperature_C
value_template: “{{ value | float }}”
unit_of_measurement: " °C"
device_class: temperature
But there comes no DATA (unknown).
What is the final step to put the right data to the sensor.
Dick
I assume you are trying to read data from rtl_433?
The you have to subscribe to the topic, not publish to it.
Example of mine where I create a HA event entity
mqtt:
  event:
    - name: "Avantek bell door"
      state_topic: rtl_433/ha-addon/events
      device_class: "button"
      unique_id: rtl433_avantek_doorbell_door
      event_types:
        - "press"
      value_template: >
          {% if value_json.model == "Avantek" and value_json.count >= 3 and     value_json.code == 18956279 and value_json.button == 40193 %}
            "event_type": "press",
            "serial": "avantek_doorbell",
            "button": "door"
          {% endif %}
Thanks for answering
I think after you comment thah the reasen is something with mosquitto pub and sub .
But i cannot see my mistake is:
rtl_433 -F json -M utc | mosquitto_pub -t “rtl_433/pi” -h “192.168.1.158” -p “1883” -u “mqtt_user” -P “mqtt_dow” –l
{“time”: “2024-05-29 12:42:46”,“model”: “Prologue-TH”,“subtype”: 9,“id”: 60,“channel”: 2,“battery_ok”: 1,“temperature_C”: 21.6,“button”: 0}
configurationfile
  • name: oregonTemperature, state_topic: rtl_433/pi/temperature_C’ unique_id:oregon_temperature_C, value_template: “{{ value | float }}”
    unit_of_measurement: " °C",device_class: temperature
I hope that this extra data is an explitaion to solve my problem
Dick
Please format any yaml code you publish.
Code_format
Your “value_template” should be {{ value_json.temperature_C | float }}
mqtt:
Bresser 5-in-1 / Bresser 6-in-1 --hass-- full context
- name: Bresser51 Temperature
  unique_id: bresser51_temperature_C
  value_template: "{{ value | float }}"
dick
thanks
Dick
