Hi everyone. Since last update of hassio 0.91… and the mosquitto official add on version 4.1 my system breaked down. All my tasmotized devices are looking to conect the mqtt broker but could not.
I configure the add on with this settings:
“logins”: [
“username”: “my username on the tasmotazed sonoffs”,
“password”: “my password on the tasmotized sonoffs”
“anonymous”: false,
“quiet_logs”: true,
“customize”: {
“active”: true,
“folder”: “mosquitto”
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”
of course the mosquitto ACCESS CONTROL LISTS (ACLS) is created as displayed on the addon
This is my log on mqqtt add on
1556145310: Socket error on client cliente36, disconnecting. 1556145310: Socket error on client cliente8, disconnecting. 1556145310: Socket error on client cliente40, disconnecting. 1556145310: Socket error on client cliente16, disconnecting. 1556145310: Socket error on client cliente22, disconnecting. 1556145310: Socket error on client cliente28, disconnecting. 1556145310: Socket error on client cliente38, disconnecting. 1556145310: Socket error on client cliente2, disconnecting. 1556145310: Socket error on client cliente37, disconnecting. 1556145310: Socket error on client cliente4, disconnecting. 1556145310: Socket error on client cliente41, disconnecting. 1556145310: Socket error on client cliente34, disconnecting. 1556145310: New connection from 192.168.1.245 on port 1883. 1556145310: New connection from 192.168.1.246 on port 1883. 1556145310: New connection from 192.168.1.244 on port 1883. 1556145310: New connection from 192.168.1.218 on port 1883. 1556145310: New connection from 192.168.1.221 on port 1883. 1556145310: New connection from 192.168.1.223 on port 1883. 1556145310: New connection from 192.168.1.248 on port 1883. 1556145310: New connection from 192.168.1.235 on port 1883. 1556145310: New connection from 192.168.1.243 on port 1883. 1556145310: New connection from 192.168.1.237 on port 1883. 1556145310: New connection from 192.168.1.214 on port 1883. 1556145310: New connection from 192.168.1.225 on port 1883. 1556145310: New connection from 192.168.1.234 on port 1883. 1556145310: New connection from 192.168.1.236 on port 1883. 1556145310: New connection from 192.168.1.240 on port 1883. 1556145310: New connection from 192.168.1.232 on port 1883. 1556145310: New connection from 192.168.1.228 on port 1883. 1556145310: New connection from 192.168.1.247 on port 1883. 1556145310: New connection from 192.168.1.242 on port 1883. 1556145310: New connection from 192.168.1.213 on port 1883. 1556145310: New connection from 192.168.1.217 on port 1883. 1556145310: New connection from 192.168.1.239 on port 1883. 1556145310: New connection from 192.168.1.233 on port 1883. 1556145310: New connection from 192.168.1.226 on port 1883. 1556145310: New connection from 192.168.1.252 on port 1883. 1556145310: New connection from 192.168.1.215 on port 1883. 1556145310: New connection from 192.168.1.253 on port 1883. 1556145310: New connection from 192.168.1.216 on port 1883. 1556145310: New connection from 192.168.1.251 on port 1883. 1556145310: New connection from 192.168.1.212 on port 1883. 1556145310: New connection from 192.168.1.219 on port 1883. 1556145310: New connection from 192.168.1.231 on port 1883. 1556145310: New connection from 192.168.1.238 on port 1883. 1556145310: New connection from 192.168.1.241 on port 1883. 1556145310: New connection from 192.168.1.244 on port 1883. 1556145310: New connection from 192.168.1.245 on port 1883. 1556145310: New connection from 192.168.1.235 on port 1883. 1556145310: New connection from 192.168.1.221 on port 1883. 1556145310: New connection from 192.168.1.246 on port 1883. 1556145310: New connection from 192.168.1.248 on port 1883. 1556145310: New connection from 192.168.1.218 on port 1883. 1556145310: New connection from 192.168.1.223 on port 1883. 1556145310: New connection from 192.168.1.243 on port 1883. 1556145310: New connection from 192.168.1.230 on port 1883. [INFO] found daniel on local database 1556145311: New client connected from 192.168.1.245 as cliente10 (c1, k10, u’daniel’). [INFO] found daniel on local database 1556145312: New client connected from 192.168.1.246 as cliente9 (c1, k10, u’daniel’). [INFO] found daniel on local database 1556145313: New client connected from 192.168.1.244 as cliente11 (c1, k10, u’daniel’). [INFO] found daniel on local database 1556145314: New client connected from 192.168.1.218 as cliente35 (c1, k10, u’daniel’). [WARN] Not found daniel on local database 1556145315: Socket error on client <unknown>, disconnecting. [INFO] found daniel on local database 1556145316: New client connected from 192.168.1.223 as cliente30 (c1, k10, u’daniel’). [INFO] found daniel on local database 1556145317: New client connected from 192.168.1.248 as cliente7 (c1, k10, u’daniel’). [INFO] found daniel on local database 1556145318: New client connected from 192.168.1.235 as cliente20 (c1, k10, u’daniel’). [INFO] found daniel on local database 1556145319: New client connected from 192.168.1.243 as cliente12 (c1, k10, u’daniel’). [INFO] found daniel on local database 1556145320: New client connected from 192.168.1.237 as cliente18 (c1, k10, u’daniel’). [INFO] found daniel on local database 1556145321: New client connected from 192.168.1.214 as cliente39 (c1, k10, u’daniel’). [INFO] found daniel on local database 1556145322: New client connected from 192.168.1.225 as cliente29 (c1, k10, u’daniel’). [INFO] found daniel on local database 1556145323: New client connected from 192.168.1.234 as cliente21 (c1, k10, u’daniel’). [INFO] found daniel on local database 1556145324: New client connected from 192.168.1.236 as cliente19 (c1, k10, u’daniel’). [INFO] found daniel on local database 1556145325: New client connected from 192.168.1.240 as cliente15 (c1, k10, u’daniel’). [INFO] found daniel on local database 1556145326: New client connected from 192.168.1.232 as cliente23 (c1, k10, u’daniel’). [INFO] found daniel on local database 1556145328: New client connected from 192.168.1.228 as cliente26 (c1, k10, u’daniel’). [INFO] found daniel on local database 1556145329: New client connected from 192.168.1.247 as cliente8 (c1, k10, u’daniel’). [WARN] Not found daniel on local database 1556145330: Socket error on client <unknown>, disconnecting. [INFO] found daniel on local database 1556145331: New client connected from 192.168.1.213 as cliente40 (c1, k10, u’daniel’). [INFO] found daniel on local database 1556145332: New client connected from 192.168.1.217 as cliente36 (c1, k10, u’daniel’). [INFO] found daniel on local database 1556145333: New client connected from 192.168.1.239 as cliente16 (c1, k10, u’daniel’).
when i go to integrations an choose mqqt configure i put all the data Host, username,password and when i executed it came with this
Unable to connect to the broker.
I have my pi assigned the ip 192.168.1.200 as always.
the extrange thing is that when i leave DHCP enable and don´t choose an static ip for the PI sometime i am eble to configure the mqqtt on integrations and back to control my lights but after a while everything go nuts again.
My router is an asus AC 5300 with aimesh along with AC 88u, I have try them without the aimesh configuration and other options on the router menus but no luck.
tasmota ver 6.5 core 2.3 and every sonoff switch could be reached and control by its IP adress inserted on the browser.
any idea whats wrong???
HEEEELLLLPPP
