When using certificate based encryption the client certificate can be used to retrieve the username. The benefit is, that the connecting device doesn’t require user-id / password. This increases security as the password isn’t stored remotely. There are two possible options available in Mosquitto:
use_identity_as_username
[ true | false ] -
use_subject_as_username
[ true | false ]
Please allow in the configuration of the Mosquitto Broker to insert configuration items such as:
use_identity_as_username: true
Thank you
Adrian
