Hi Everyone, i hope you guys can help me.
I am using a Arduino Mega with Ethernet Shield and some buttons.
MQTT on it aswell.
When i click a button i publish this payload: “20-45” on topic: “buttons”
Its always the same payload, how can i automate that so when i click the button its changing states in home-assistant?
I know the different between pub and sub, but i cant get my head to think of a solution for this, can you guys help?
/DkAutomater
Thanks VDRainer, but can i add to a switch or sensor?
Or will it only work in automations?
Its working in a automations, so that is really nice, thanks.
Meaby i will just stick to this.
VDRainer
November 25, 2018, 7:12pm
5
You can also use the MQTT Binary Sensor if the payload is always the same.
Do you mean like this?:
- platform: mqtt
name: "MQTT Binary Sensor1"
state_topic: "buttons"
payload_on: "20-44"
VDRainer
November 25, 2018, 7:27pm
7
With the proper intentation
binary_sensor:
- platform: mqtt
payload_on: "20-44"
it should work.
Its change from off to on, but after next button press, its keep on the binary sensor.
And i dont have two payloads, one for on and one for off.
So that will not work.
VDRainer
November 25, 2018, 7:35pm
9
For this there’s the off_delay
option in the sensor.
off_delay
(integer)(Optional)For sensors that only sends ‘On’ state updates, this variable sets a delay in seconds after which the sensor state will be updated back to ‘Off’.
Like this
- platform: mqtt
payload_on: "20-44"
off_delay: "1"
Its not working, its keep the state on after 1 click on the button.
Does not work with this:
- platform: mqtt
payload_on: "20-44"
off_delay: 1
The state is off after i reboot the system, when i click the button, the state goes on and keeps on, not going back to off state.
Could you try meaby to see if its only me that have this issue?
VDRainer
November 25, 2018, 8:59pm
14
binary_sensor:
- platform: mqtt
state_topic: "home/tests/button1"
payload_on: "20-44"
off_delay: 1
Works for me.
Sensor goes to on, 1 second later to off.
Publish with:
mosquitto_pub -h <mqtt_broker> -t "home/tests/button1" -m "20-44"
VDRainer:
platform: mqtt name: “MQTTBinarySensor1” state_topic: “home/tests/button1” payload_on: “20-44” off_delay: 1
Does not work for me, its keep the on state all the time.
Very odd.
I created a switch, and i make an automation that change that state of that switch, so i can automate with that switch.
But still odd its not working with the binary sensor.
I dont use the latest version, so this should not be an issue.
djax
(Djax)
February 24, 2020, 11:26pm
19
if off_delay has been canceled in Nov 2018, is it still relevant to be in the documentation in Feb 2020?
https://github.com/home-assistant/home-assistant/pull/18389
Best regards
