MQTT CCT light with 2 channels of light
Hello can someone little bit experienced help me with configuration of MQTT LIGHT template.
I have one light controlled via DMX protocol (2 channels):
  • 1 channel is for 3000K led (warm white)
  • 1 channel is for 6000K led (neutral or daylight white)
As a DMX - MQTT gateway I am using this Gateway / DMX / MQTT
The dimmer for this light listen on topics:
  • DMX1 for first channel (integer value from 0 - 255, 0=light turn off, 255=100% of light)
  • DMX2 for second channel (integer value from 0 - 255, 0=light turn off, 255=100% of light)
I need to write a MQTT LIGHT configuration template for this CCT light mixing the right white temperature and brightness to this 2 MQTT topics.
Thank you for any advice.
