Hi All,
I’m trying to configure 4 relays for a ceiling fan in my bedroom with 3 speeds and a light switch.
I’m able to configure everything from home assistant to the Raspberry using MQTT with the help of a lot of forum topics here.
But, does someone knows if it’s possible to require a switch in off state before the pressed switch goes to On state?
This is to prevent 2 relays being in On state, which will result in a dead fan.
