I am getting a Client was not initialized error every time I publish to the MQTT broker.
Any ideas?
E (37270) MQTT_CLIENT: Client was not initialized
if(strcmp(payload, "/pool/valve/5/off") == 0)
valve_5_NC();
esp_mqtt_client_publish(client, "/pool/state/topic/5", "/pool/valve/state/5/off", 0, 0, 1);
static const char *TAG = "MQTT_EXAMPLE";
static void log_error_if_nonzero(const char *message, int error_code)
if (error_code != 0)
ESP_LOGE(TAG, "Last error %s: 0x%x", message, error_code);
* @brief Event handler registered to receive MQTT events
* This function is called by the MQTT client event loop.
* @param handler_args user data registered to the event.
* @param base Event base for the handler(always MQTT Base in this example).
* @param event_id The id for the received event.
* @param event_data The data for the event, esp_mqtt_event_handle_t.
char *payload = NULL;
int new_data = 0;
static void mqtt_event_handler(void *handler_args, esp_event_base_t base, int32_t event_id, void *event_data)
ESP_LOGD(TAG, "Event dispatched from event loop base=%s, event_id=%d", base, event_id);
esp_mqtt_event_handle_t event = event_data;
esp_mqtt_client_handle_t client = event->client;
int msg_id;
switch ((esp_mqtt_event_id_t)event_id) {
case MQTT_EVENT_CONNECTED:
ESP_LOGI(TAG, "MQTT_EVENT_CONNECTED");
msg_id = esp_mqtt_client_publish(client, "/pool/topic/qos0", "data_3", 0, 1, 0);
ESP_LOGI(TAG, "sent publish successful, msg_id=%d", msg_id);
msg_id = esp_mqtt_client_subscribe(client, "/pool/topic/qos0", 0);
ESP_LOGI(TAG, "sent subscribe successful, msg_id=%d", msg_id);
msg_id = esp_mqtt_client_subscribe(client, "/pool/topic/qos0", 1);
msg_id = esp_mqtt_client_unsubscribe(client, "");
ESP_LOGI(TAG, "sent unsubscribe successful, msg_id=%d", msg_id);
break;
case MQTT_EVENT_DISCONNECTED:
ESP_LOGI(TAG, "MQTT_EVENT_DISCONNECTED");
break;
case MQTT_EVENT_SUBSCRIBED:
ESP_LOGI(TAG, "MQTT_EVENT_SUBSCRIBED, msg_id=%d", event->msg_id);
msg_id = esp_mqtt_client_publish(client, "/pool/topic/qos0", "data", 0, 0, 0);
break;
case MQTT_EVENT_UNSUBSCRIBED:
ESP_LOGI(TAG, "MQTT_EVENT_UNSUBSCRIBED, msg_id=%d", event->msg_id);
break;
case MQTT_EVENT_PUBLISHED:
ESP_LOGI(TAG, "MQTT_EVENT_PUBLISHED, msg_id=%d", event->msg_id);
break;
case MQTT_EVENT_DATA:
ESP_LOGI(TAG, "MQTT_EVENT_DATA");
printf("TOPIC=%.*s\r\n", event->topic_len, event->topic);
printf("DATA=%.*s\r\n", event->data_len, event->data);
payload = event->data;
new_data = 1;
break;
case MQTT_EVENT_ERROR:
ESP_LOGI(TAG, "MQTT_EVENT_ERROR");
if (event->error_handle->error_type == MQTT_ERROR_TYPE_TCP_TRANSPORT) {
log_error_if_nonzero("reported from esp-tls", event->error_handle->esp_tls_last_esp_err);
log_error_if_nonzero("reported from tls stack", event->error_handle->esp_tls_stack_err);
log_error_if_nonzero("captured as transport's socket errno", event->error_handle->esp_transport_sock_errno);
ESP_LOGI(TAG, "Last errno string (%s)", strerror(event->error_handle->esp_transport_sock_errno));
break;
default:
ESP_LOGI(TAG, "Other event id:%d", event->event_id);
break;
static void mqtt_app_start(void)
esp_mqtt_client_config_t mqtt_cfg = {
.uri = "mqtt://192.168.1.25",
.username = "MQTT",
.password = "Password"
esp_mqtt_client_handle_t client = esp_mqtt_client_init(&mqtt_cfg);
/* The last argument may be used to pass data to the event handler, in this example mqtt_event_handler */
esp_mqtt_client_register_event(client, ESP_EVENT_ANY_ID, mqtt_event_handler, NULL);
esp_mqtt_client_start(client);
