Would be great to have the left upper icon showing orange (as the state of the corresponding thermostat card itself) and the left under icon showing green (as the state of the corresponding thermostat card).
Just like this … as it works for standard climate entities.
Many thanks, will certainly have a look for it.
However a standard climate entity has the colors shown in a standard entity card. Where a mqtt climate entity doesn’t show color of the icon.
Is this because it’s not implemented in the HA yet, or do you need to configure it in your mqtt climate entity itself?
Does anyone knows this?
Hi, yes normally are there min and max temperatures.
It’s orange for heating, blue for cooling, …
Would be great to have the colors matching. It works for the mqtt climate entity when you use the entity in a thermostat card, there you see the color of the state (orange= heating, blue = cooling, …). However when you putt the same mqtt entity in a standard entity card, then you don’t see the corresponding colors. For a regular climate entity the color is shown.
Hi @sheminasalam
I didn’t configured the mqqt climate entities myself, as they are automatically created using an addon.
However there is a min and max temperate defined.
