I am having a problem setting the target temp.
Mqtt has a temperate/cmd ,heatingtemp/cmd, and coolingtemp/cmd coming from smart things hub.
Would anyone be able help me understand this? Looking at the documentation there is only a way to send temperate command. But my system uses heat temperature command if in heat mode and cooling temperature command if in cooling mode.
Smartthings bridge:
smartthings/2Gig CT100 Programmable Thermostat/battery/cmd
smartthings/2Gig CT100 Programmable Thermostat/coolingSetpoint/cmd
smartthings/2Gig CT100 Programmable Thermostat/heatingSetpoint/cmd
smartthings/2Gig CT100 Programmable Thermostat/humidity/cmd
smartthings/2Gig CT100 Programmable Thermostat/temperature/cmd
smartthings/2Gig CT100 Programmable Thermostat/thermostatFanMode/cmd
smartthings/2Gig CT100 Programmable Thermostat/thermostatMode/cmd
smartthings/2Gig CT100 Programmable Thermostat/thermostatOperatingState/cmd
smartthings/2Gig CT100 Programmable Thermostat/thermostatSetpoint/cmd
I have tried setpoint/cmd to no avail.
