MQTT Climate Sensor Range Limits
It appears that an MQTT based climate sensor cant set temps below 7 (45 F) or 35 (95 F) at least via the UI. I have the following config:
climate:
 - platform: mqtt
    initial: 32
    min_temp: 0
    temperature_command_topic: "myhome/wine/setfinmintemp"
    temperature_state_topic: "ha/wine/finMinTemp"
    current_temperature_topic: "ha/wine/Fin Temp"
    mode_state_topic: "ha/wine/Defrosting"
    modes:
      - "Defrosting"
      - "Normal"
    swing_modes:
    fan_modes:
Its working fine within that range but the UI won’t let me go above or below those limits. I did find those limits referenced here:
https://github.com/home-assistant/home-assistant/blob/dev/homeassistant/components/climate/init.py
Can someone help confirm this restriction before I move on to another approach?
