MQTT Code Errors
I have a MQTT/Tasmota basd Dimmer Switch.
I have used the following code to place in my MQTT file.
  - platform: mqtt
    state_topic: "stat/dimmer_office/POWER"
    command_topic: "cmnd/dimmer_office/POWER"
    availability_topic: "tele/dimmer_office/LWT"
    brightness_state_topic: "stat/dimmer_office/RESULT"
    brightness_command_topic: "cmnd/dimmer_office/Dimmer"
    brightness_scale: 100
    brightness_value_template: "{{ value_json.Dimmer }}"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    payload_available: "Online"
    payload_not_available: "Offline"
    retain: false
But after a config check it gives me the following error.
Invalid config for [switch.mqtt]: [brightness_state_topic] is an invalid option for [switch.mqtt]. Check: switch.mqtt->brightness_state_topic. (See ?, line ?).
Can someone explain firstly what I have done incorrectly and then how to fix it.
You want it to be an MQTT light, not an MQTT switch.
Brightness is for lights, not switches. Shouldn’t this be an mqtt light?
Edit - ninja’d :wink:
