Mqtt config in Yaml
I need help with my mqtt setup on Home Assistant running on Raspberry Pi 3. I am missing something really simple I apologise for the long and probably incorrectly formatted post. Any tips would be appreciated.:grimacing:
I have a series of NodeMCU’s with DHT22 sensors that, at the moment, point to a RPi running NodeRed. This gives a nice result, but for a more integrated dashboard I’d like to point the outputs to Home Assistant. I have also set up a stand alone NodeMCU that points directly at Home Assistant
I have loaded the mqtt broker(v1.0) to Home Assistant and the log shows the following:
starting version 3.2.2
1514676267: mosquitto version 1.4.12 (build date 2017-06-01 13:03:48+0000) starting
1514676267: Config loaded from /etc/mosquitto.conf.
1514676267: Opening ipv4 listen socket on port 1883.
1514676267: Opening ipv6 listen socket on port 1883.
1514676267: Warning: Mosquitto should not be run as root/administrator.
1514676278: New connection from 10.1.1.189 on port 1883.
1514676278: New client connected from 10.1.1.189 as mqtt_7f095960.80f6a8 (c1, k60).
1514676294: New connection from 10.1.1.77 on port 1883.
1514676294: New client connected from 10.1.1.77 as Bedroom_3 (c1, k120).
The connection from 10.1.1.189 is from the NodeRed setup, 10.1.1.77 is direct from the NodeMCU (ESP8266)
So I know that Home Assistant is seeing the two feeds, but my overview shows an invalid config message
“The following components and platforms could not be set up:
  • mqtt
  • sensor.mqtt
    Please check your config.”
My Yaml file looks like this.
homeassistant:
`# Name of the location where Home Assistant is running
Location required to calculate the time the sun rises and sets
latitude: -37.0000000
longitude: 144.0000000
Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 25
metric for Metric, imperial for Imperial
unit_system: metric
Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Australia/Melbourne
Customization file
customize: !include customize.yaml
Show links to resources in log and frontend
introduction:
Enables the frontend
frontend:
Enables configuration UI
config:
http:
Secrets are defined in the file secrets.yaml
api_password: my secret
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
base_url: mydns
Checks for available updates
Note: This component will send some information about your system to
the developers to assist with development of Home Assistant.
For more information, please see:
https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
Optional, allows Home Assistant developers to focus on popular components.
include_used_components: true
Discover some devices automatically
discovery:
Allows you to issue voice commands from the frontend in enabled browsers
conversation:
Enables support for tracking state changes over time
history:
View all events in a logbook
logbook:
Enables a map showing the location of tracked devices
map:
Track the sun
sun:
Weather prediction
  • platform: yr
Text to speech
tts:
  • platform: google
group: !include groups.yaml
script: !include scripts.yaml
weather:
  • platform: bom
  • platform: bom
    station: IDV60901.95866
    monitored_conditions:
    • apparent_t
    • wind_dir
    • wind_spd_kmh
  • platform: bom
    station: IDV60901.95936
    • apparent_t
    • wind_dir
    • wind_spd_kmh
  • platform: scrape
    resource: http://www.bom.gov.au/vic/forecasts/melbourne.shtml
    select: ‘.max’
    unit_of_measurement: ‘Max °C’
  • platform: scrape
    select: ‘.min’
    unit_of_measurement: ‘Min °C’
  • platform: scrape
    select: ‘p:nth-of-type(4)’
    unit_of_measurement: ‘Nil’
  • platform: mqtt
    state_topic: Bedroom_3
    unit_of_measurement: ’ C’
camera:
For future use, you need to post your configuration.yaml file using the instructions in the big blue box at the top of the page.
But a quick glance shows that you don’t have an mqtt: section. See
