Hope someone can help me out with this problem I cannot solve during the past two days. I am new to MQTT.
I try to run a WiFi Sensor ESP8266 via MQTT. While the sensor was running fine before via Thingspeak in HA, I decided to setup the sensor for HA via MQTT.
I do not think the sensor is the problem, it has something to do that HA cannot connect with the MQTT broker.
I have a separate laptop with HA OS on IP 192.168.178.37
I setup a new user in HA with the name: mqtt-user
I added MQTT client to addons
I added the integration MQTT
The last one gives the error: Not Loaded
I have mqtt explorer installed on my desktop Windows computer and it connects, I think, but I am unsure what to do here.
In the file editor, under configuration, I added the following:
mqtt:
broker: 192.168.178.37 # Use the correct Mosquitto hostname if it’s running locally (spaces at the beginning are lost in editor)
port: 1883
username: mqtt-user
password: Mqtt5tgb
platform: mqtt
state_topic: “home/sensor/co2”
unit_of_measurement: “ppm”
value_template: “{{ value | int }}”
The LOG gave me the following:Logger: homeassistant.config
Source: config.py:940
First occurred: 16:03:32 (1 occurrences)
Last logged: 16:03:32
Invalid config for ‘mqtt’ at configuration.yaml, line 1: ‘broker’ is an invalid option for ‘mqtt’, check: mqtt->0->broker, please check the docs at MQTT - Home Assistant
Setup failed for ‘mqtt’: Invalid config.
The mqtt platform for the sensor integration does not support platform setup. Please remove it from your config.
Thanks Koying, I removed all from Configuration and it looks already a lot better. No error messages in the integration mqtt. However, any sensor declaration gives a fault.
Do I need to declare any sensor in configuration?
When I add the following, he complians about using “platform”
mqtt:
platform: mqtt
state_topic: “home/sensors/temperature”
unit_of_measurement: “°C”
MESSAGE
It’s not possible to configure mqtt sensor by adding platform: mqtt to the sensor configuration. To resolve this: Remove platform: mqtt occurences from the sensor: configuration in your YAML configuration file.
I tried some other config syntax but these return other errors.
Maybe you have an example, so I can mod it to my applcation?
Alright, true… I thought I do a quick go with help of chatgpt. Better to start reading. The problem however that there aren’t much examples. Did not expect this kind of time investment. Anyway. Thanks.
Edit: It works now with the following in configurations.yaml
mqtt:
- name: My temperature
unit_of_measurement: “C”
- name: My CO2 level
state_topic: “home/sensors/co2”
Note with copy paste: Be sure you make a 2 space indent with “sensor”: and then also 2 spaces indent to “-”. state is directly under name.
