Can someone help me determine if there is a current bug with regards to the mqtt configuration setup? Below is the section of my configuration that causes the configuration validator to spin constantly and never complete when I comment out the “OLD” section and try to use the uncommented “NEW” section. If I leave the “OLD” area uncommented (while also commenting out the “NEW” area) and validate, the validation completes successfully.
I have had this problem since the original announcement of the changeover to the new code styling of the mqtt sensor. And was hoping this issue might have been a bug and had been fixed in one of the subsequent HA versions but whatever is going on seems to still be an issue.-- Maybe something in my new code is not right but I’m pretty sure I matched it identically from old to new unless I’m missing something completely??
Thank you all for any insights/ help you can provide. I can post a video of this behavior and link to it if necessary.
When getting the constant spinning, I am pretty much just commenting out the “old” and uncommenting the “new” but maybe there is something else I’m not catching
I copied your entire package contents above into my test config running 2022.9.2 and the validation check works fine. I used it with the new and old alternately commented out and both validate just fine.
EDIT:
wait…I just noticed I have something else strange going on…
Ahh, you may have caught the issue there!! Let me check this the next time I get back to my PC and I’ll report what I find out.
If I have other sections of the Mqtt sensor in that package, can I use the old code style on some and the new code style on some? I think this is what I was attempting to do and just need to move that “sensor:” farther down in the file to where more of the old Mqtt code style exists— unless I’m dreaming and there are not anymore.— in that case, I def need to comment it out like you’re thinking.
Let me mess with this, this evening and let’s see what happens.
Thank you so much @finity, this has been driving me bonkers.
OK, so I have messed with this a bit more tonight trying to simplify things to get to the bottom of whatever is going on. Below is my current package file that is causing the validator to never complete. See if you see any issues with this one. I believe I corrected what you were speaking of in your previous post but it seems like it still won’t validate for some reason. This is blowing my mind. (Currently below I have both the old code style and new code style in use)
Thank you for trying to help me figure this out. I really don’t understand what’s going on
input_boolean:
washer_finished:
icon: mdi:washing-machine
input_number:
stepper_control_right_test_blind:
name: Stepper Control Right Test Blind
min: -200
max: 460
step: 1
mode: slider
stepper_control_left_test_blind:
name: Stepper Control Left Test Blind
min: -200
max: 700
step: 1
mode: slider
#####NEW######
mqtt:
- name: "Washer Status"
state_topic: "house/washer/status"
- name: "Washer Last Complete"
state_topic: "house/washer/time_complete"
device_class: timestamp
- name: "Washer Last Emptied"
state_topic: "house/washer/time_emptied"
#####/NEW######
#####/OLD######
# - platform: "mqtt"
# name: "Washer Status"
# state_topic: "house/washer/status"
# name: "Washer Last Complete"
# state_topic: "house/washer/time_complete"
# device_class: timestamp
# name: "Washer Last Emptied"
# state_topic: "house/washer/time_emptied"
# # MQTT Sensor for DishWasher Status.
# - platform: mqtt
# name: "DishWasher Status"
# state_topic: "house/dishwasher/status"
# MQTT Sensor for Washing Machine Status.
# One entry for each beacon you want to track
- platform: mqtt_room
device_id: "apple:1006:10-8"
name: 'Westons iPhone Room Presence'
state_topic: 'espresense/devices/apple:1006:10-8'
timeout: 10
away_timeout: 120
#####/OLD######
####NOT USING CURRENTLY####
# - platform: mqtt_room
# device_id: 123testid
# state_topic: "espresense/rooms"
####/NOT USING CURRENTLY####
utility_meter:
washer_daily_kwh:
source: sensor.washer_switch_electric_consumed_kwh
cycle: daily
washer_weekly_kwh:
cycle: weekly
automation:
- id: washer_running
alias: Washer Running
- above: 4
entity_id: sensor.washer_power_consumed_w
platform: numeric_state
condition:
condition: or
conditions:
- condition: state
entity_id: sensor.washer_status
state: idle
- condition: state
state: complete
- service: mqtt.publish
topic: house/washer/status
payload: running
retain: true
initial_state: true
- id: washer_complete
alias: Washer Complete
- below: 2
condition:
- condition: state
state: running
payload: complete
retain: true
topic: house/washer/time_complete
payload: "{{ utcnow().isoformat() }}"
# payload: '{{ now().timestamp() }}'
retain: true
initial_state: true
- id: washer_notification
initial_state: true
alias: Washer Notification
- platform: state
to: complete
- service: script.speech_engine
# who: 'kitchen'
message: "Just a quick heads up, It appears the washing machine has completed its cycle"
- service: script.text_notify
who: parents
title: Washing Machine Finished
group: "appliances"
tag:
- service: script.turn_on
entity_id: script.washer_finished_notification_audible
data: {}
entity_id: input_boolean.washer_finished
- id: washer_emptied
initial_state: true
alias: Washer Emptied
- platform: state
entity_id: binary_sensor.washer_door
to: "on"
payload: idle
retain: true
- service: script.turn_off
topic: house/washer/time_emptied
retain: true
- service: input_boolean.turn_off
data: {}
script:
washer_finished_notification_audible:
sequence:
- repeat:
while:
- condition: state
state: "complete"
sequence:
- delay:
minutes: 30
- service: script.simplified_washer_audible
simplified_washer_audible:
sequence:
- condition: state
entity_id: group.family
state: "home"
- condition: state
state: complete
# who: 'kitchen'
message: >
'Pardon me, ',
'Excuse me, ',
'I do not mean to interrupt, but,',
'I hate to interrupt, but,',
'I beg your pardon, ',
'I do not mean to intrude, but, ',
'I am sorry to interrupt, but. ',
'Just a quick heads up, '
] | random }}
<p>
The washing machine completed its cycle
{% set seconds = now().timestamp() - as_timestamp(states.sensor.washer_status.last_changed) %}
{% if (seconds / ( 60 * 60 )) | int == 1 %}
over an hour ago.
'Do not forget to rotate the clothes.',
'Was someone going to rotate the laundry?',
'Once you rotate the laundry I will stop reminding you to do it. So if you want me to stop. Its up to you.'
] | random }}
{% elif (seconds / ( 60 * 60 )) | int > 1 and (seconds / ( 60 * 60 )) | int < 6 %}
over {{ (seconds // ( 60 * 60 )) | int }} hours ago.
'Much longer and you are going to need to wash them again.',
'Someone needs to rotate the laundry.',
'Do not forget about the clothes in the washing machine.',
'Surely you did not mean to forget about the clothes. Mistakes happen. But you can still fix it.',
'Do you like your clothes smelling like mildew? Becasue that is what is happening right now.'
] | random }}
{% elif (seconds / ( 60 * 60 )) | int > 6 %}
'That is a crazy amount of time.',
'Did you decide you want those clothes to suffer?',
'You might as well just rewash those clothes.',
'I can smell the mildew. Virtually that is.',
'Surely you did not mean to forget about the clothes.'
] | random }}
{% else %}
{{ (seconds // 60) | int }} minutes ago.
'Someone forgot to move the clothes to the dryer. I am not going to name names, but there is a camera in there. Do I need to publically shame someone?',
'You might want to move them to the dryer.'
] | random }}
{% endif %}
</p>
washer_idle:
sequence:
payload: idle
retain: true
washer_running:
sequence:
payload: running
retain: true
washer_complete:
sequence:
payload: complete
retain: true
retain: true
I finally got my production HA up to date (2022.9.7) and copied the above latest code directly into my config and it validates fine. So I really don’t know what might be going on with yours.
You might be able to try to just comment everything out in that package file and add one section back in at a time until it fails.
then skip that section (leaving it commented out) and move on to the next.
then when you have it completely checked and hopefully narrowed down to the exact section that is failing then add a bit of the offending section back in until it fails again.
If I have other packages with Mqtt stuff in them. Could they be interfering somehow? They would be in the old format also. I think I have some blinds created in earphone that have a few Mqtt sensors being created in them but they are completely external to the Mqtt items in the package that we have been discussing.
I will try this. But I’m fairly certain I may have done this before and it worked fine until I uncommented the last section (which was the “new” code section)— I’ll give this idea another try tomorrow and see if I hopefully get a different result.
