Heffot416
(Vincent)
1
Hello i am currently following this github: hassio-plejd/plejd/README.md at 7bdcc60205bdb14ca6c44e54002aac1530d7d02d · icanos/hassio-plejd · GitHub
And at the “Simple MQTT Configurations”/“Configuration Parameters”
He tells us to change the parameters but i cant find where to do it?
Sir_Goodenough
((SG) WhatAreWeFixing.Today)
2
Hello Vincent,
In the MQTT Add-on it appears.
You did see this in the requirements as well, right? In the configuration for that.
Requirements:
An MQTT broker (the Mosquitto broker Home Assistant add-on works perfectly well).
koying
(Chris B)
3
Actually, I think it’s in that plejd addon configuration that you have to specify how the addon would connect to “a” MQTT broker.
Sir_Goodenough
4
Both is likely, but at the exact point they ask the question about they are talking about adding login and password to the mosquito add-on.
koying
(Chris B)
5
Well, the question is about “changing parameters”, which I understand as “where do I put those parameters”. If so, it’s in the plejd addon config.
From the doc, I understand the MQTT addon userbase is shared with HA, so you create new users in the UI, not through YAML parameters
