I’m new to home assistant and have problems with the setup of home assistant.
The documentation I found so far assumes that you now how home assistant works. But at this point I still don’ t understand the structure how to configure home assistant.
I want to integrate zigbee2mqtt. when I look in the log of zigbee2mqtt I see that message are successful posted to the mqtt broker.
When I try to read the sensor data in home assistant i got this message: This integration has no devices.
I don’ t understand what it means? is the device zigbee2mqtt or the zigbee temperature sensor?
Where are the log messages of the embedded mqtt broker? how do I debug it?
how do I disable the embedded mqtt broker? and use mosquitto.
what does this message mean, what is the problem? how do i solve it?
Is there any more detailed information how to configure it.
I use hassbian because if you login at hass.io there is nothing. Where is the linux environment?
I solved it. But now for sure. But I think the problem was. That a password is mandatory. So after adding that i got it working.
Also reading back the mqtt message with mosquitto is also a big help in solving the problem.
Success.
