Which fixed things somewhat, the sensors reapear and report data but MQTT seems to be stuck in a loop of opening and closing the connection so the sensors connect/disconnect repeatedly.
Jul 03 16:37:15 hassbian mosquitto[423]: 1499121435: Client sensornode1 disconnected.
Jul 03 16:37:15 hassbian mosquitto[423]: 1499121435: New client connected from 192.168.1.206 as sensornode1 (c1, k15, u’pi’).
Jul 03 16:37:19 hassbian mosquitto[423]: 1499121439: New connection from 192.168.1.20 on port 1883.
Jul 03 16:37:19 hassbian mosquitto[423]: 1499121439: Client sensornode1 already connected, closing old connection.
Jul 03 16:37:19 hassbian mosquitto[423]: 1499121439: Client sensornode1 disconnected.
Jul 03 16:37:19 hassbian mosquitto[423]: 1499121439: New client connected from 192.168.1.20 as sensornode1 (c1, k15, u’pi’).
Jul 03 16:37:20 hassbian mosquitto[423]: 1499121440: New connection from 192.168.1.206 on port 1883.
Jul 03 16:37:20 hassbian mosquitto[423]: 1499121440: Client sensornode1 already connected, closing old connection.
Jul 03 16:37:20 hassbian mosquitto[423]: 1499121440: Client sensornode1 disconnected.
Jul 03 16:37:20 hassbian mosquitto[423]: 1499121440: New client connected from 192.168.1.206 as sensornode1 (c1, k15, u’pi’).
Can you tell what you changed i am also stuck in error
New connection from 192.168.0.211 on port 1883.
Sep 13 13:52:57 HA mosquitto[30869]: 1505335977: Socket error on client <unknown>, disconnecting.
Sep 13 13:52:58 HA mosquitto[30869]: 1505335978: New connection from 192.168.1.21 on port 1883.
Sep 13 13:52:58 HA mosquitto[30869]: 1505335978: Client home-assistant-1 already connected, closing old connection.
Sep 13 13:52:58 HA mosquitto[30869]: 1505335978: Client home-assistant-1 disconnected.
Sep 13 13:52:58 HA mosquitto[30869]: 1505335978: New client connected from 192.168.0.211 as home-assistant-1 (c1, k60, u'username').
Oh i just check you are on hasbian. My setup is on All in one… Will it also effect i don’t see any OTA name. I tried changing name for MQTT server but still same.
Can anyone help with the MQTT Error - All was working fine before update. I have reverted back to 0.51 but still getting error -
Sep 13 13:52:58 HA mosquitto[30869]: 1505335978: New client connected from 192.168.0.21 as home-assistant-1 (c1, k60, u'username').
