MQTT Connection delay
I run a ESP8266 that send out a door state (open ,close) before going to deep sleep for a while.
Since it is powered by a battery I want to by as quick as possible to connect + send MQTT message.
I made some (very stable) mesurements (wake-up & sending frequence = 1 minute) :
Mosquitto broker configuration : version: 5.1.1
Plateform : raspi3
Core : core-2021.4.6
  • before_mqtt : 74 ms to connect to WIFI
  • awake time : Total awake time : 596 ms including MQTTbroker connection and sending
That means
  • 74ms to connect to WIFI (excellent)
  • 500ms+ to make the connection which is a huge delay compare to WIFI connection.
Do you have ideas where this delay comes from ?
I’ll make some additionnal tests with a stand alone MQTT brocker installed on my lap top…
By pushing my investigations I noticed that every 5 minutes (every 6 sending) the MQTT connection & sending takes not 500 ms but almost 2 sec where as the WIFI connection delay stays inchanged.
Did you have a similar issue on Mosquitto brocker connection ?
Here the screenshots :
Thiis is the root cause:
The solution is to upgrade to v6.0.1 (most recent) or downgrade to v5.1
Hello and thank you Maxym
I made 2 investigations :slight_smile:
  • MQTT version update to V6.0.1
    Unfortunately no improvement with the version update but non additionnal delay afer 5mn.
    So slight improvement…
{"device":4,"door_state":"close","Vbatt":3331,"before_mqtt":76,"awake_time":597}
  • Mosquitto brocker on my lap top
    Same behavior except no additionnal delay after 5mn
{"device":4,"door_state":"close","Vbatt":3355,"before_mqtt":77,"awake_time":600}
So I’ll focus to my c++
After some software improvement, I finally achieve to reduce significatly the connection delay
I finally get 254 ms to connect to wifi, connect to MQTT brocker, send payload and return to deep sleep which is really excellent.
That ensures years with one 18650 battery.
