It is using the same config file as per full log file from service restart
root@pine64:/home/homeassistant/.homeassistant# sudo systemctl restart home-assistant@homeassistant && sudo journalctl -f -u home-assistant@homeassistant
-- Logs begin at Wed 2017-12-06 18:01:39 EET. --
Dec 06 18:54:04 pine64 hass[6799]: 2017-12-06 18:54:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=automation.cooldown, old_state=<state automation.cooldown=off; friendly_name=Cooldown, last_triggered=None @ 2017-12-06T18:54:02.420456+02:00>, new_state=<state automation.cooldown=on; friendly_name=Cooldown, last_triggered=None @ 2017-12-06T18:54:04.027104+02:00>>
Dec 06 18:54:04 pine64 hass[6799]: 2017-12-06 18:54:04 INFO (MainThread) [homeassistant.core] Timer:starting
Dec 06 18:54:04 pine64 hass[6799]: 2017-12-06 18:54:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_automations, old_state=<state group.all_automations=off; hidden=True, order=0, auto=True, assumed_state=False, entity_id=('automation.cooldown', 'automation.heatup'), friendly_name=all automations @ 2017-12-06T18:54:02.461982+02:00>, new_state=<state group.all_automations=on; hidden=True, order=0, auto=True, assumed_state=False, entity_id=('automation.cooldown', 'automation.heatup'), friendly_name=all automations @ 2017-12-06T18:54:04.037940+02:00>>
Dec 06 18:54:08 pine64 systemd[1]: Stopping Tapulin Kotitonttu for user homeassistant...
Dec 06 18:54:08 pine64 hass[6799]: 2017-12-06 18:54:08 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_stop[L]>
Dec 06 18:54:11 pine64 hass[6799]: 2017-12-06 18:54:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_close[L]>
Dec 06 18:54:11 pine64 hass[6799]: Config directory: /home/homeassistant/.homeassistant
Dec 06 18:54:12 pine64 systemd[1]: Stopped Tapulin Kotitonttu for user homeassistant.
Dec 06 18:54:12 pine64 systemd[1]: Starting Tapulin Kotitonttu for user homeassistant...
Dec 06 18:54:42 pine64 systemd[1]: Started Tapulin Kotitonttu for user homeassistant.
Dec 06 18:54:47 pine64 hass[6842]: 2017-12-06 18:54:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
Dec 06 18:54:47 pine64 hass[6842]: 2017-12-06 18:54:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
Dec 06 18:54:47 pine64 hass[6842]: 2017-12-06 18:54:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=toggle>
Dec 06 18:54:47 pine64 hass[6842]: 2017-12-06 18:54:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
Dec 06 18:54:47 pine64 hass[6842]: 2017-12-06 18:54:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=restart>
Dec 06 18:54:47 pine64 hass[6842]: 2017-12-06 18:54:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=check_config>
Dec 06 18:54:47 pine64 hass[6842]: 2017-12-06 18:54:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=reload_core_config>
Dec 06 18:54:47 pine64 hass[6842]: 2017-12-06 18:54:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=persistent_notification, service=create>
Dec 06 18:54:47 pine64 hass[6842]: 2017-12-06 18:54:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=persistent_notification, service=dismiss>
Dec 06 18:54:47 pine64 hass[6842]: 2017-12-06 18:54:47 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized
Dec 06 18:54:47 pine64 hass[6842]: 2017-12-06 18:54:47 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history
Dec 06 18:54:47 pine64 hass[6842]: 2017-12-06 18:54:47 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
Dec 06 18:54:47 pine64 hass[6842]: 2017-12-06 18:54:47 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http
Dec 06 18:54:47 pine64 hass[6842]: 2017-12-06 18:54:47 INFO (MainThread) [homeassistant.loader] Loaded mqtt from homeassistant.components.mqtt
Dec 06 18:54:47 pine64 hass[6842]: 2017-12-06 18:54:47 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
Dec 06 18:54:47 pine64 hass[6842]: 2017-12-06 18:54:47 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api
Dec 06 18:54:47 pine64 hass[6842]: 2017-12-06 18:54:47 INFO (MainThread) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
Dec 06 18:54:47 pine64 hass[6842]: 2017-12-06 18:54:47 INFO (MainThread) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
Dec 06 18:54:47 pine64 hass[6842]: 2017-12-06 18:54:47 INFO (MainThread) [homeassistant.setup] Setting up mqtt
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 ERROR (MainThread) [homeassistant.setup] Error during setup of component mqtt
Dec 06 18:54:48 pine64 hass[6842]: Traceback (most recent call last):
Dec 06 18:54:48 pine64 hass[6842]: File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 190, in _async_setup_component
Dec 06 18:54:48 pine64 hass[6842]: result = yield from component.async_setup(hass, processed_config)
Dec 06 18:54:48 pine64 hass[6842]: File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/mqtt/__init__.py", line 387, in async_setup
Dec 06 18:54:48 pine64 hass[6842]: success = yield from hass.data[DATA_MQTT].async_connect()
Dec 06 18:54:48 pine64 hass[6842]: File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/mqtt/__init__.py", line 498, in async_connect
Dec 06 18:54:48 pine64 hass[6842]: self._mqttc.connect, self.broker, self.port, self.keepalive)
Dec 06 18:54:48 pine64 hass[6842]: File "/usr/lib/python3.5/asyncio/futures.py", line 361, in __iter__
Dec 06 18:54:48 pine64 hass[6842]: yield self # This tells Task to wait for completion.
Dec 06 18:54:48 pine64 hass[6842]: File "/usr/lib/python3.5/asyncio/tasks.py", line 296, in _wakeup
Dec 06 18:54:48 pine64 hass[6842]: future.result()
Dec 06 18:54:48 pine64 hass[6842]: File "/usr/lib/python3.5/asyncio/futures.py", line 274, in result
Dec 06 18:54:48 pine64 hass[6842]: raise self._exception
Dec 06 18:54:48 pine64 hass[6842]: File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
Dec 06 18:54:48 pine64 hass[6842]: result = self.fn(*self.args, **self.kwargs)
Dec 06 18:54:48 pine64 hass[6842]: File "/srv/homeassistant/lib/python3.5/site-packages/paho/mqtt/client.py", line 768, in connect
Dec 06 18:54:48 pine64 hass[6842]: return self.reconnect()
Dec 06 18:54:48 pine64 hass[6842]: File "/srv/homeassistant/lib/python3.5/site-packages/paho/mqtt/client.py", line 895, in reconnect
Dec 06 18:54:48 pine64 hass[6842]: sock = socket.create_connection((self._host, self._port), source_address=(self._bind_address, 0))
Dec 06 18:54:48 pine64 hass[6842]: File "/usr/lib/python3.5/socket.py", line 711, in create_connection
Dec 06 18:54:48 pine64 hass[6842]: raise err
Dec 06 18:54:48 pine64 hass[6842]: File "/usr/lib/python3.5/socket.py", line 702, in create_connection
Dec 06 18:54:48 pine64 hass[6842]: sock.connect(sa)
Dec 06 18:54:48 pine64 hass[6842]: ConnectionRefusedError: [Errno 111] Connection refused
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_data=message=The following components and platforms could not be set up:
Dec 06 18:54:48 pine64 hass[6842]: - [mqtt](https://home-assistant.io/components/mqtt/)
Dec 06 18:54:48 pine64 hass[6842]: Please check your config., notification_id=invalid_config, title=Invalid config, domain=persistent_notification, service=create, service_call_id=548421938592-1>
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state persistent_notification.invalid_config=notifying; message=The following components and platforms could not be set up:
Dec 06 18:54:48 pine64 hass[6842]: Please check your config., title=Invalid config @ 2017-12-06T18:54:48.111675+02:00>, entity_id=persistent_notification.invalid_config>
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=548421938592-1>
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.setup] Setting up recorder
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=recorder, service=purge>
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.setup] Setting up http
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=http>
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.setup] Setting up api
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.setup] Setting up system_log
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=websocket_api>
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.1 seconds.
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=api>
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=system_log, service=clear>
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.1 seconds.
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=system_log>
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.setup] Setting up frontend
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.1 seconds.
Dec 06 18:54:48 pine64 hass[6842]: 2017-12-06 18:54:48 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=frontend>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 1.2 seconds.
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=recorder>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.setup] Setting up history
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=history>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.loader] Loaded switch from homeassistant.components.switch
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.loader] Loaded group from homeassistant.components.group
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.loader] Loaded switch.mqtt from homeassistant.components.switch.mqtt
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.loader] Loaded sensor.mqtt from homeassistant.components.sensor.mqtt
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.setup] Setting up sensor
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.loader] Loaded config from homeassistant.components.config
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.loader] Loaded panel_iframe from homeassistant.components.panel_iframe
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.loader] Loaded google from homeassistant.components.google
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.loader] Loaded automation from homeassistant.components.automation
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.loader] Loaded automation.time from homeassistant.components.automation.time
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.setup] Setting up group
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.setup] Setting up config
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.setup] Setting up panel_iframe
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of sensor.mqtt. Setup failed for dependencies: mqtt
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform sensor.mqtt: Could not setup all dependencies.
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.loader] Loaded config.group from homeassistant.components.config.group
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.group>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.loader] Loaded config.core from homeassistant.components.config.core
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.core>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.loader] Loaded config.hassbian from homeassistant.components.config.hassbian
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.loader] Loaded config.automation from homeassistant.components.config.automation
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.automation>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.loader] Loaded config.customize from homeassistant.components.config.customize
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.customize>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.loader] Loaded config.script from homeassistant.components.config.script
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.script>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_data=message=The following components and platforms could not be set up:
Dec 06 18:54:49 pine64 hass[6842]: - [mqtt](https://home-assistant.io/components/mqtt/)
Dec 06 18:54:49 pine64 hass[6842]: - sensor.mqtt
Dec 06 18:54:49 pine64 hass[6842]: Please check your config., notification_id=invalid_config, title=Invalid config, domain=persistent_notification, service=create, service_call_id=548421938592-2>
Dec 06 18:54:49 pine64 hass[6842]: Please check your config., notification_id=invalid_config, title=Invalid config, domain=persistent_notification, service=create, service_call_id=548421938592-3>
Dec 06 18:54:49 pine64 hass[6842]: Please check your config., notification_id=invalid_config, title=Invalid config, domain=persistent_notification, service=create, service_call_id=548421938592-4>
Dec 06 18:54:49 pine64 hass[6842]: Please check your config., notification_id=invalid_config, title=Invalid config, domain=persistent_notification, service=create, service_call_id=548421938592-5>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.setup] Setup of domain panel_iframe took 0.2 seconds.
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=panel_iframe>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=<state persistent_notification.invalid_config=notifying; message=The following components and platforms could not be set up:
Dec 06 18:54:49 pine64 hass[6842]: Please check your config., title=Invalid config @ 2017-12-06T18:54:48.111675+02:00>, new_state=<state persistent_notification.invalid_config=notifying; message=The following components and platforms could not be set up:
Dec 06 18:54:49 pine64 hass[6842]: Please check your config., title=Invalid config @ 2017-12-06T18:54:48.111675+02:00>, entity_id=persistent_notification.invalid_config>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=548421938592-2>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=548421938592-3>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=548421938592-4>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=548421938592-5>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.3 seconds.
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=sensor>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=group, service=reload>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=group, service=set>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=group, service=remove>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=group, service=set_visibility>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.3 seconds.
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=group>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.3 seconds.
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.setup] Setting up switch
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.setup] Setting up automation
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state automation.cooldown=off; friendly_name=Cooldown, last_triggered=None @ 2017-12-06T18:54:49.791048+02:00>, entity_id=automation.cooldown>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state automation.heatup=off; friendly_name=Heatup, last_triggered=None @ 2017-12-06T18:54:49.793629+02:00>, entity_id=automation.heatup>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of switch.mqtt. Setup failed for dependencies: mqtt
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform switch.mqtt: Could not setup all dependencies.
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_data=object_id=all_automations, entities=['automation.cooldown', 'automation.heatup'], name=all automations, visible=False, domain=group, service=set, service_call_id=548421938592-6>
Dec 06 18:54:49 pine64 hass[6842]: - switch.mqtt
Dec 06 18:54:49 pine64 hass[6842]: Please check your config., notification_id=invalid_config, title=Invalid config, domain=persistent_notification, service=create, service_call_id=548421938592-7>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state group.all_automations=off; hidden=True, assumed_state=False, friendly_name=all automations, order=0, auto=True, entity_id=('automation.cooldown', 'automation.heatup') @ 2017-12-06T18:54:49.852154+02:00>, entity_id=group.all_automations>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=548421938592-6>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=548421938592-7>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=trigger>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=reload>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=toggle>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=turn_on>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=turn_off>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.1 seconds.
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=automation>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
Dec 06 18:54:49 pine64 hass[6842]: 2017-12-06 18:54:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=switch, service=toggle>
