Does ‘mqtt : - cover’ , still works in a similar way like ‘mqtt: -switch’ .
I get error when using ‘cover’ after mqtt.
Hi ,
This is the Docs for MQTT Cover if that helps…
And you can put this into a search engine to get the experience of others on this site:
site:community.home-assistant.io mqtt cover
Thank. Found my mistake. It was helpful
If you have what you need, please consider posting the solution tag to close the thread.
