I am trying to get MQTT Cover working here, using the configuration.yaml from the components page. The commands work fine: the relay is activated for up, down, and stop so that part works. But the entity state is stuck on “Unknown”. Subscribing to the state_topic shows the state changes (“open”, “closed”) as expected, but that info never makes it into home assistant (running hassio, MQTT broker is mosquitto on a separate Pi server).
I got home-assistant mainly to open and close that stupid door. I am enjoying all the other features/components, but this door thing is driving me crazy. Any ideas would be welcome.
platform: mqtt
state_topic: “home-assistant/cover/state_topic”
command_topic: “home-assistant/cover/set”
qos: 1
retain: true
payload_open: “OPEN”
payload_close: “CLOSE”
payload_stop: “STOP”
state_open: “OPEN”
state_closed: “CLOSED”
optimistic: false
value_template: ‘{{ value.x }}’
The only log entry I can find is from the hassio homeassistant log:
2017-08-17 00:38:46 WARNING (MainThread) [homeassistant.components.cover.mqtt] Payload is not True, False, or integer (0-100):
Nothing in the HA logbook. States shows the cover.garage_door as “unknown”. The GarageQTPi config.yaml is:
mqtt:
host: localhost
port: 1883
user: user
password: password
doors:
relay: 22
state: 17
state_mode: normally_closed #defaults to normally open, uncomment to switch
The relay works as it should, mosquitto_sub sees the state response come back, i.e. “OPEN” or “CLOSED” but HA itself never sees this, or never shows it to me.
Client mosqsub/2633-core-ssh received PUBLISH (d0, q0, r0, m0, ‘home-assistant/cover/state_topic’, … (4 bytes))
home-assistant/cover/state_topic OPEN
Client mosqsub/2633-core-ssh received PUBLISH (d0, q0, r0, m0, ‘home-assistant/cover/state_topic’, … (6 bytes))
home-assistant/cover/state_topic CLOSED
And just like that it works! I am pretty sure I had tried that earlier but that was before I sorted out the user and API password. Thanks for that, now I can move on to automations. Much appreciated!
claughinghouse1m
Has anyone had any luck with garage door wall panels that do not just require breaking or completing a circuit? I have a Genie 2028 and the wall panel has a PCB in it.
I wired GarageQtPi in and was able to successfully turn the light on the wall panel on and off but not activate the garage door.
It seems that the garage door is expecting some sort of signal from the wall panel since it has a light activate button, vacation mode, and door open/close using only 2 wires.
Anyone have any ideas where to look to see if this is possible with my or similar models?
