Hi, I’m new using homeassistant. I’m trying to implement a Shelly 2 device over MQTT. It’s in a seperate folder for covers.
My configuration:
- platform: mqtt
name: “MQTT test cover”
qos: 0
retain: true
optimistic: false
state_topic: “shellies/shellyswitch-5B23AA/roller/0”
command_topic: “shellies/shellyswitch-5B23AA/roller/0/command”
payload_open: “open”
payload_close: “close”
payload_stop: “stop”
position_topic: “shellies/shellyswitch-5B23AA/roller/0/pos”
set_position_topic: “shellies/shellyswitch-5B23AA/roller/0/command/pos”
position_closed: 100
position_open: 0
#tilt_status_topic: “shellies/shellyswitch-5B23AA/roller/0/pos”
#tilt_command_topic: “shellies/shellyswitch-5B23AA/roller/0/command/pos”
#tilt_min: 0
#tilt_max: 100
#tilt_closed_value: 0
#tilt_opened_value: 100
value_template: ‘{{ value.x }}’
Log:
2019-04-10 20:31:13 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-04-10 20:31:14 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
I tried it with the tilt option and its working but I do not understand why the slider for position is not appearing.
Thanks in advance
