Hi there,
with the help of this forum I had implemented my covers from fhem via mqtt to homeassistant.
Even though, the covers are already in the new format, they aren’t recognized by home-assistant.
the covers in question are defined by mqtt: !include_dir_merge_named mqtt/
in configuration.yaml the following definition in mqtt/fhem_rollos.yaml
cover:
- name: Fhem_Rollo_01
unique_id: "fhemRollo01neu"
state_topic: "fhem/Rollo_Nr_01/state"
position_topic: "fhem/Rollo_Nr_01/pct"
command_topic: "fhem/set/Rollo_Nr_01/state"
set_position_topic: "fhem/set/Rollo_Nr_01/pct"
<<: &FhemRolloAnker
value_template: >-
{%- if value == "open" -%}
{{"open"}}
{%- elif value == "closed" -%}
{{"closed"}}
{%- elif value == "drive-up" -%}
{{"opening"}}
{%- elif value == "drive-down" -%}
{{"closing"}}
{%- else -%}
{{"stopped"}}
{%- endif %}
set_position_template: " {% if (position%10) > 5 %} {{ position - position%10 +10 }} {% else %} {{position - position%10 }} {% endif %}"
payload_available: "true"
payload_not_available: "false"
payload_open: "open"
payload_close: "closed"
payload_stop: "stop"
position_open: 100
position_closed: 0
optimistic: false
qos: 1
- name: Fhem_Rollo_02
unique_id: "fhemRollo02"
state_topic: "fhem/Rollo_Nr_02/state"
position_topic: "fhem/Rollo_Nr_02/pct"
command_topic: "fhem/set/Rollo_Nr_02/state"
set_position_topic: "fhem/set/Rollo_Nr_02/pct"
<<: *FhemRolloAnker
Strangely, these covers won’t work, while some covers defined as the following in mqtt/shelly_rollos.yaml
will work:
cover:
- name: DgRollo
unique_id: "shelly_25_DgRollo"
command_topic: "shellies/shellyswitch25-D8BFC01A2E91/roller/0/command" # rc, open, close and stop
state_topic: "shellies/shellyswitch25-D8BFC01A2E91/roller/0" # open, close, stop
position_topic: "shellies/shellyswitch25-D8BFC01A2E91/roller/0/pos"
set_position_topic: "shellies/shellyswitch25-D8BFC01A2E91/roller/0/command/pos"
#availability_topic: "shellies/shellyswitch25-D8BFC01A2E91/online"
#json_attributes_topic: shellies/shellyswitch25-D8BFC01A2E91/info
payload_close: "close"
#state_opening: open
#state_closing: close
position_open: 100
position_closed: 0
optimistic: false
qos: 1
Has anybody any clue, what’s going on?
I verified on the topics, because I can listen to them and set them via the configuration.
I’ve tried without the anchors but without any luck.
So I’m out of ideas and need your help
