Hi there,
can anybody help me? I’m really confused right now…
I have some older remote controlled covers, which are controlled via fhem and some magic
Because I want to controll them via homeassistant, I connected them via mqtt and defined the cover in homeassistant like this:
- platform: mqtt
unique_id: "fhemRollo01"
command_topic: "fhem/Rollo_Nr_01/set"
position_topic: "fhem/Rollo_Nr_01/homekit_pos"
position_template: "{{ position }}"
set_position_topic: "fhem/Rollo_Nr_01/set"
set_position_template: "{{'position_homekit '}}{{ position }}"
#availability_topic: "fhem/connection/status"
payload_available: "true"
payload_not_available: "false"
payload_open: "open"
payload_close: "closed"
payload_stop: "stop"
state_opening: "drive-up"
state_closing: "drive-down"
position_open: 100
position_closed: 0
optimistic: false
qos: 1
At first sight, this works rather well. I can open and close them via the buttons and I can the position via the slider.
But there are some problems:
- It doesn’t show me the state of the cover. My covers are closed at 0% and open at 100%. This is not reflected in homeassistant. Is it possible to calculate the state from the position? I thought,
position_open: 100 position_closed: 0
would be sufficent. - Because my cover integration in fhem only accepts multiples of 10% as values for the covers, it is very hard to control the position via the slider in the dashboard. What is the best way to control and send only multiples of 10 as the position?
- Bonus question: Let’s say I didn’t want to put 20+ covers with nearly identical mqtt topics in my configuration. Are anchors the way to do this?
If you are still reading this, thank you.
At last but not least, I’d like to apologise for butchering the english grammar but english is not my native tongue.
