Mqtt cover with two command topics?
Hello.
I use Shelly UNI to control main gate of a house
It works well for years but now I’m thinking about how to turn it into a cover entity.
The problem is that to achieve open and close in current setup, I use two separate inputs of the device to trigger 2 inputs if the gate controller. It requires to send command to two different mqtt topics.
Unfortunately an MQTT cover entity allows to define only one command topic.
Do you have experience with such setup or have idea how to approach that?
Of course I can create a two-way proxy between what I have and what’s required for a cover. But maybe there is more straightforward way
thank you
If you create a normal template cover entity, you can call scripts for any operation. In that script you can put whatever you currently use / send two mqtt commands using services.
