MQTT Creating Sensor from Array (?)
I have the following data from my MQTT topic:
    "zoneData": {
        "holidays": [
                "index": 0,
                "fromAsIso": "2023-02-21",
                "toAsIso": "2023-02-24",
                "added": false,
                "deleted": false,
                "changed": false,
                "osv": false
I guess this is an array? I fail creating a sensor for the value “fromAsIso”. The only thing I am able to create, is a sensor Elco holidays:
mqtt:
    - name: Elco Holidays
      unique_id: elco_holidays
      state_topic: "remocon/hvac"
      value_template: "{{ value_json.zoneData.holidays }}"
The value of this sensor is:
[{‘index’: 0, ‘fromAsIso’: ‘2023-02-21’, ‘toAsIso’: ‘2023-02-24’, ‘added’: False, ‘deleted’: False, ‘changed’: False, ‘osv’: False}]
I have tried the following, which apparently did not work:
mqtt:
    - name: Elco Holidays Start Date
      unique_id: elco_holiday_startDate
      value_template: "{{ value_json.zoneData.holidays.fromAsIso }}"
    - name: Elco Holidays Start Date V2
      unique_id: elco_holiday_startDate2
      value_template: "{{ value_json.zoneData.holidays[1] }}"
I couldn’t find anything in the forum.
value_json.zoneData.holidays[0]
EDIT: you can copy/paste it in a viewer to help getting the path, e.g Online JSON Viewer (stack.hu)
Thanks for your help! I have found what I need thanks to your answer.
The solution is:
value_json.zoneData.holidays[0].fromAsIso
