MQTT Device not sending necessary Informations
Hello everyone, I have been running the Fhem server for my smart home project for the past few years. Now I installed Home Assistant a few days ago, as I would like to switch in the long term.
I am currently still having difficulties with one or two issues and need your help. Unfortunately, Chat-GPT couldn’t really help me.
I have a Tasmota sensor which sends me values from my electricity meter via MQTT to my broker at IP 192.168.178.99. This also works more or less.
However, I cannot read the sensor within Home Assistant. As soon as I try to select the entity, I get the error that this is not available.
The MQTT explorer shows me all the required values. The values are also displayed in Fhem without any problems.
Meine configuration.yaml
Blockquote
mqtt:
- name: “Stromzaehler SML2 Power”
state_topic: “Strom/tele/SENSOR” # Hier sicherstellen, dass das richtige Topic verwendet wird
value_template: “{{ value_json.SML2.Power_curr }}” # Der Wert von Power_curr aus der JSON-Nachricht
unit_of_measurement: “W”
device_class: power
unique_id: “0DEC7B_SML2_Power_curr”
MQTT-Explorer Information:
Blockquote
“SML2”: {
“Power_curr”: 379,
“Power_curr”: 365,
“Total_in”: 26445.89,
“Meter_number”: “09014953XXXXXXXXXX”
I would be happy if someone could help me with this. thank you in advance!
Please re-post your code formatted correctly. Use the </> button. Should look like this:
mqtt:
    - name: (uzw)
You have pasted it as a blockquote, which destroys indentation and exchanges “real” quotes for “smart” ones. There might be errors in your code that are not apparent to us.
If this is your first MQTT sensor in the configuration file, you must restart HA to load it up.
If that doesn’t help, please paste a screenshot from MQTT Explorer showing the topic and the data.
Where are you trying to “select the entity”, and what does the error look like?
Have you set up your MQTT broker in HA? Do you have a screen like this under Integrations?
Thanks for your help. Unfortunately everything is in german. I hope you can unterstand it anyway :slight_smile:
Every time I change something in the configuration.yaml, I reload it and also restart Home Assistant.
mqtt:
    - name: "Stromzaehler SML2 Power"
      state_topic: "Strom/tele/SENSOR"  # Hier sicherstellen, dass das richtige Topic verwendet wird
      value_template: "{{ value_json.SML2.Power_curr }}"  # Der Wert von Power_curr aus der JSON-Nachricht
      unit_of_measurement: "W"
      device_class: power
      unique_id: "0DEC7B_SML2_Power_curr"
unfortunatly i can post only 1 image…
An error occurred: Sorry, new users can only put one embedded media item in a post.
Thanks. Although they should be supported, I would remove the comments in the YAML, so:
Are you certain you have the MQTT topic correct? Is this the only mqtt: section in your configuration.yaml?
If it’s still not working, try:
mqtt:
      value_template: "{{ value[:250] }}"
with the other lines deliberately removed. The state of that sensor should now be the first 250 characters of the topic response, just to check that any data is getting through.
Now you should be able to reply with the MQTT Explorer screenshot :slight_smile:
The screenshot the OP posted is a device that was automatically discovered (via MQTT) by the Tasmota integration. The device is a switch with several sensors (all appear to be unavailable).
The OP appears to be trying to rectify the situation by manually defining an MQTT Sensor … which is also reporting it’s unavailable.
There appears to be an underlying problem that affects both automatically and manually created entities for the device.
This is how my configuration.yaml looks like:
omeassistant:
  latitude: XXX  # Breite, z.B. für Berlin
  longitude: XXX  # Länge, z.B. für Berlin
  elevation: 34  # Höhe über dem Meeresspiegel
  unit_system: metric  # metrisches System (Celsius, km/h)
  country: DE  # Land, z.B. Deutschland
  currency: EUR  # Währung
  country_code: de  # Ländercode
  time_zone: "Europe/Berlin"  # Zeitzone
  media_dirs:
    media: "/mnt/your_media_folder"  # Pfad für Medieninhalte
# Automatisierungen und Szenen
scene: !include scenes.yaml
# Beispiel für eine einfache Wetterintegration
weather:
  - platform: openweathermap
    api_key: "YOUR_OPENWEATHERMAP_API_KEY"
# Beispiel für eine MQTT-Integration (Smart Home Geräte)
mqtt:
      device_class: power
# Beispiel für eine Lichtsteuerung mit MQTT
light:
  - platform: mqtt
    state_topic: "home/lights/livingroom/state"
    command_topic: "home/lights/livingroom/set"
    brightness_state_topic: "home/lights/livingroom/brightness/state"
    brightness_command_topic: "home/lights/livingroom/brightness/set"
    payload_on: "ON"
    payload_off: "OFF"
# Beispiel für einen MQTT-Sensor (Temperatur)
  - platform: mqtt
    state_topic: "home/sensors/temperature"
    unit_of_measurement: "°C"
switch:
  - platform: mqtt
    name: "NOUS A1T Steckdose"
    state_topic: "stat/nous_a1t_steckdose/tasmota_181194"
    command_topic: "cmnd/nous_a1t_steckdose/tasmota_181194"
    payload_on: "ON"
    payload_off: "OFF"
    qos: 1
# Beispiel für eine Benutzerdefinierte Automation
automation:
  - alias: "Licht einschalten bei Bewegung"
      platform: state
      entity_id: binary_sensor.motion_sensor
      to: "on"
      service: light.turn_on
        entity_id: light.wohnzimmer_lampe
# Zigbee2MQTT Integration
zigbee2mqtt:
  mqtt:
    base_topic: zigbee2mqtt
    server: "mqtt://localhost"
    user: "mqtt_user"
    password: "mqtt_password"
  permit_join: false
  device_options:
    - option1: value1
    - option2: value2
# Beispiel für die Integration von Alexa
alexa:
  smart_home:
    endpoint: "https://api.amazonalexa.com/v3"
    client_id: "your_alexa_client_id"
    client_secret: "your_alexa_client_secret"
