I wanted to share the changes I needed to make for HA 2022.6 specific to MQTT device tracking used for presence detection i.e. person
state associated with tracked device.
Here are my notes – I hope anyone can correct anything that’s incorrect or if there is a better solution after upgrading:
I could not find a way to use consider_home
. Previously using the device_tracker
platform for MQTT, you could set that parameter “globally” in your config, for example:
- platform: mqtt
# Start global setting
consider_home: 60
# End global setting
devices:
joelp_phone: "tracker/mac/xx:xx:xx:xx:xx:xx"
I use a DIY solution that tracks WiFi clients on my Unifi APs and publishes a retained MQTT message for each client. The payload is home
. The retained message allows consistent state between restarts and also avoids a state of unknown
when no message is present (i.e. it defaults to away
What consider_home
allowed was a configurable delay in a presence change to away
. To make this work for MQTT devices, you had to delete the retained message (i.e. send empty payload) as opposed to sending a payload of not_home
. I couldn’t find this behavior documented clearly outside HA source code.
Also, if there is no retained message for the device, the associated person state defaults to unknown
. You have to account for this in any automations.
Now that I use the mqtt/device_tracker
for my tracked devices, I had to change my solution to send a payload of not_home
instead of deleting the retained message.
I hope this helps.
