I have two Schneider Electrics shutter controller connected to my Home Assistant with Zigbee that were working correctly until I updated the HA to the core-2022.2.6 version.
Now the control buttons to move the shutter are all grayed and the automations are not running anymore.
The devices and entities are still there, the only ‘strange’ thing is that the entities status says resotred with a red exclamation mark icon.
On the Zigbee2mqtt GUI both devices appears as before and can be operated from there.
In the past I had some similar problem that was solved removing and reinstalling the Zigbee2mqtt add-on, but in this case it is not working.
Yeah “restored” is a bad name for this. It means they were there, now they aren’t. They are “restored” as in their config has been restored/loaded from the .storage registry after a restart but the devices aren’t available.
Are there any errors in your log?
Were there any breaking changes for this integration in the release?
There are two breaking changes for MQTT but relative to light switches and climate, they should not affect my devices.
The log contains few errors but they are about google assistant:
2022-02-15 11:03:22 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:reportStateAndNotification failed: 404
2022-02-15 11:43:48 ERROR (MainThread) [homeassistant.components.google_assistant.smart_home] Unexpected error
File "/usr/src/homeassistant/homeassistant/components/google_assistant/smart_home.py", line 57, in _process
result = await handler(hass, data, inputs[0].get("payload"))
File "/usr/src/homeassistant/homeassistant/components/google_assistant/smart_home.py", line 213, in handle_devices_execute
execute_results = await asyncio.wait_for(
File "/usr/local/lib/python3.9/asyncio/tasks.py", line 481, in wait_for
return fut.result()
File "/usr/src/homeassistant/homeassistant/components/google_assistant/smart_home.py", line 157, in _entity_execute
await entity.execute(data, execution)
File "/usr/src/homeassistant/homeassistant/components/google_assistant/helpers.py", line 641, in execute
await trt.execute(command, data, params, challenge)
File "/usr/src/homeassistant/homeassistant/components/google_assistant/trait.py", line 1904, in execute
await self.hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1577, in async_call
raise ServiceNotFound(domain, service) from None
homeassistant.exceptions.ServiceNotFound: Unable to find service cover.close_cover
2022-02-15 11:43:48 ERROR (MainThread) [homeassistant.components.google_assistant.smart_home] Error handling message {'inputs': [{'context': {'locale_country': 'US', 'locale_language': 'en'}, 'intent': 'action.devices.EXECUTE', 'payload': {'commands': [{'devices': [{'id': 'cover.kitchen_shutter'}], 'execution': [{'command': 'action.devices.commands.OpenClose', 'params': {'followUpToken': '008e8db1ad664e08c09c2ea6c2affa5d4d326942b395a977408114d1e9979e6f10036ed2155c38a57f8ba5ee9f3fdb2cb6579eb9', 'openPercent': 0}}]}]}}], 'requestId': '2310301423882392649'}: {'errorCode': 'unknownError'}
In zigbee2mqtt, what happens if you change the name of one of the shutter controllers and turn on the update home assistant toggle (you can change it back later, just a test)?
Does it update the name of the device in home assistant?
Does it fix the issue?
Either way, you can change the name back, remembering to turn on the toggle to update home assistant.
And it did not create a new device with the new name?
Sounds like there is something wrong with the discovery messages zigbee2mqtt is publishing to the broker. Maybe only for these devices. Try a different type of device.
