I have a problem where all my DIY devices using Wemos D1 Mini have stopped working. They connect to Home Assistant via MQTT, but all of them are showing as unavailable. I can see in the logs that the devices are connecting, but they don’t appear on the dashboard—they’re marked as unavailable. This issue started occurring one day ago. HA also showed me that there is something deprecated (the message is not showing anymore). I’m not sure what the problem is. Below is my part of configuration.yaml:
mqtt:
cover:
- name: "Kitchen Shades"
command_topic: "homeassistant/sensor/kitchen_shades/pos"
position_topic: "homeassistant/sensor/kitchen_shades/position"
set_position_topic: "homeassistant/sensor/kitchen_shades/set_position"
availability_topic: "homeassistant/sensor/kitchen_shades/availability"
qos: 0
retain: true
payload_open: "OPEN"
payload_close: "CLOSE"
payload_stop: "STOP"
position_open: 0
position_closed: 100
payload_available: "online"
payload_not_available: "offline"
optimistic: false
unique_id: "kitchen_shades_001"
switch:
- unique_id: post_switch_001
command_topic: "homeassistant/sensor/post/set"
state_topic: "homeassistant/sensor/post/swstate"
availability_topic: "homeassistant/sensor/post/availability"
payload_on: "ON"
payload_off: "OFF"
state_on: "ON"
state_off: "OFF"
optimistic: false
qos: 0
retain: true
- name: "Outdoor Temperature"
state_topic: "homeassistant/weatherstation/temperatureOut"
unit_of_measurement: "°C"
qos: 0
unique_id: "weatherstation_temperatureOut"
availability_topic: "homeassistant/weatherstation/availability"
- name: "Outdoor Humidity"
state_topic: "homeassistant/weatherstation/humidityOut"
unit_of_measurement: "%"
qos: 0
unique_id: "weatherstation_humidityOut"
- name: "Wind Speed"
state_topic: "homeassistant/weatherstation/windSpeed"
unit_of_measurement: "m/s"
qos: 0
unique_id: "weatherstation_windSpeed"
- name: "Max Wind Speed"
state_topic: "homeassistant/weatherstation/maxWindSpeed"
qos: 0
unique_id: "weatherstation_maxWindSpeed"
- name: "Wind Description"
state_topic: "homeassistant/weatherstation/windDescription"
qos: 0
unique_id: "weatherstation_windDescription"
