Hi
I cannot understand why there are all these errors:
1560193598: Socket error on client DVES_9E7F66, disconnecting.
1560193625: Socket error on client DVES_9574B1, disconnecting.
1560193625: Client DVES_9E81DE has exceeded timeout, disconnecting.
1560193625: Socket error on client DVES_9E81DE, disconnecting.
1560193635: Client DVES_9E8ADB has exceeded timeout, disconnecting.
1560193635: Socket error on client DVES_9E8ADB, disconnecting.
1560193659: New connection from 192.168.1.212 on port 1883.
[INFO] found pierrescerri on Home Assistant
1560193661: New client connected from 192.168.1.212 as DVES_9E8ADB (c1, k10, u'pierrescerri').
1560193683: Client DVES_9E8ADB has exceeded timeout, disconnecting.
1560193683: Socket error on client DVES_9E8ADB, disconnecting.
1560193688: Client DVES_9E7F51 has exceeded timeout, disconnecting.
1560193688: Socket error on client DVES_9E7F51, disconnecting.
1560193689: Client DVES_9E81DB has exceeded timeout, disconnecting.
1560193689: Socket error on client DVES_9E81DB, disconnecting.
1560193691: New connection from 192.168.1.211 on port 1883.
1560193693: New client connected from 192.168.1.211 as DVES_9E7F51 (c1, k10, u'pierrescerri').
1560193693: New connection from 192.168.1.205 on port 1883.
1560193695: New client connected from 192.168.1.205 as DVES_9E81DB (c1, k10, u'pierrescerri').
1560193702: Client DVES_9E8051 has exceeded timeout, disconnecting.
1560193702: Socket error on client DVES_9E8051, disconnecting.
1560193710: New connection from 192.168.1.210 on port 1883.
1560193712: New client connected from 192.168.1.210 as DVES_9E8051 (c1, k10, u'pierrescerri').
1560193720: Socket error on client DVES_9E7F51, disconnecting.
1560193724: New connection from 192.168.1.211 on port 1883.
1560193726: New client connected from 192.168.1.211 as DVES_9E7F51 (c1, k10, u'pierrescerri').
1560193735: Client DVES_9E8051 has exceeded timeout, disconnecting.
1560193735: Socket error on client DVES_9E8051, disconnecting.
1560193745: New connection from 192.168.1.210 on port 1883.
1560193747: New client connected from 192.168.1.210 as DVES_9E8051 (c1, k10, u'pierrescerri').
1560193752: Client DVES_9E81DB has exceeded timeout, disconnecting.
1560193752: Socket error on client DVES_9E81DB, disconnecting.
1560193773: New connection from 192.168.1.205 on port 1883.
1560193775: New client connected from 192.168.1.205 as DVES_9E81DB (c1, k10, u'pierrescerri').
1560193812: Client DVES_9E81DB has exceeded timeout, disconnecting.
1560193812: Socket error on client DVES_9E81DB, disconnecting.
1560193824: Client DVES_9E81D9 has exceeded timeout, disconnecting.
1560193824: Socket error on client DVES_9E81D9, disconnecting.
1560193828: New connection from 192.168.1.206 on port 1883.
1560193830: New client connected from 192.168.1.206 as DVES_9E81D9 (c1, k10, u'pierrescerri').
1560193830: Socket error on client DVES_9E8051, disconnecting.
1560193830: New connection from 192.168.1.205 on port 1883.
1560193830: New connection from 192.168.1.210 on port 1883.
1560193832: New client connected from 192.168.1.205 as DVES_9E81DB (c1, k10, u'pierrescerri').
1560193834: New client connected from 192.168.1.210 as DVES_9E8051 (c1, k10, u'pierrescerri').
1560193837: New connection from 192.168.1.204 on port 1883.
1560193839: New client connected from 192.168.1.204 as DVES_9E81DE (c1, k10, u'pierrescerri').
1560193839: New connection from 192.168.1.203 on port 1883.
1560193841: New client connected from 192.168.1.203 as DVES_9E7F66 (c1, k10, u'pierrescerri').
1560193841: New connection from 192.168.1.212 on port 1883.
1560193843: New client connected from 192.168.1.212 as DVES_9E8ADB (c1, k10, u'pierrescerri').
1560193847: New connection from 192.168.1.213 on port 1883.
1560193849: New client connected from 192.168.1.213 as DVES_9574B1 (c1, k10, u'pierrescerri').
1560195203: Saving in-memory database to /data/mosquitto.db.
1560197004: Saving in-memory database to /data/mosquitto.db.
1560198805: Saving in-memory database to /data/mosquitto.db.
1560200606: Saving in-memory database to /data/mosquitto.db.
1560202407: Saving in-memory database to /data/mosquitto.db.
1560204208: Saving in-memory database to /data/mosquitto.db.
1560206009: Saving in-memory database to /data/mosquitto.db.
1560207810: Saving in-memory database to /data/mosquitto.db.
1560209611: Saving in-memory database to /data/mosquitto.db.
1560211412: Saving in-memory database to /data/mosquitto.db.
1560213213: Saving in-memory database to /data/mosquitto.db.
1560215014: Saving in-memory database to /data/mosquitto.db.
1560216815: Saving in-memory database to /data/mosquitto.db.
1560218616: Saving in-memory database to /data/mosquitto.db.
1560220240: Client DVES_8048A5 has exceeded timeout, disconnecting.
1560220240: Socket error on client DVES_8048A5, disconnecting.
1560220241: New connection from 192.168.1.209 on port 1883.
1560220244: New client connected from 192.168.1.209 as DVES_8048A5 (c1, k10, u'pierrescerri').
1560220417: Saving in-memory database to /data/mosquitto.db.
1560222218: Saving in-memory database to /data/mosquitto.db.
1560224019: Saving in-memory database to /data/mosquitto.db.
1560225820: Saving in-memory database to /data/mosquitto.db.
1560227622: Saving in-memory database to /data/mosquitto.db.
1560229423: Saving in-memory database to /data/mosquitto.db.
1560231224: Saving in-memory database to /data/mosquitto.db.
1560233025: Saving in-memory database to /data/mosquitto.db.
1560234826: Saving in-memory database to /data/mosquitto.db.
1560236627: Saving in-memory database to /data/mosquitto.db.
1560238428: Saving in-memory database to /data/mosquitto.db.
This results in all my Sonoffs (Tasmota 6.5.0 on Sonoff Duals and POWs and 5.12.0 on Sonoff Basic) randomly disappearing from HA. Access through individual IP’s is fine when the blue LED is not flashing like so:
Running Hassio 0.94.1 on RPi 3B connected to ethernet.
