Hey community!
I’m a bit stuck. Or sleep deprived. Or something.
I’m trying to get discovery via MQTT working, but I want to be able to publish the icon_template value. It works fine with a normal icon. I believe it’s possible on a normal sensor, although the documentation suggests it only working for a binary sensor?
Here’s the error I get when I rebooted the server (you know, in case: turn it off and on again):
2021-01-11 22:28:33 ERROR (MainThread) [homeassistant.util.logging] Exception in async_discover_sensor when dispatching ‘mqtt_discovery_new_sensor_mqtt’: ({‘name’: ‘Battery State of Charge (GE)’, ‘state_topic’: ‘givenergy/cloud/summary’, ‘availability_topic’: ‘givenergy/cloud/status’, ‘payload_available’: ‘Online’, ‘payload_not_available’: ‘Offline’, ‘json_attributes_topic’: ‘givenergy/cloud/summary’, ‘unit_of_measurement’: ‘%’, ‘value_template’: “{{value_json[‘soc’]}}”, ‘icon_template’: “{%- if value_json[‘soc’] <= ‘100’ and value_json[‘soc’] > ‘96’ and states.sensor.battery_power_2.state >= ‘0’ %} mdi:battery {% elif value_json[‘soc’] <= ‘95’ and value_json[‘soc’] > ‘90’ and states.sensor.battery_power_2.state >= ‘0’ %} mdi:battery-90 {% elif value_json[‘soc’] <= ‘89’ and value_json[‘soc’] > ‘80’ and states.sensor.battery_power_2.state >= ‘0’ %} mdI:battery80 {% elif value_json[‘soc’] <= ‘79’ and value_json[‘soc’] > ‘70’ and states.sensor.battery_power_2.state >= ‘0’ %} mdi:battery70 {% elif value_json[‘soc’] <= ‘69’ and value_json[‘soc’] > ‘60’ and states.sensor.battery_power_2.state >= ‘0’ %} mdi:battery60 {% elif value_json[‘soc’] <= ‘59’ and value_json[‘soc’] > ‘50’ and states.sensor.battery_power_2.state >= ‘0’ %} mdi:battery50 {% elif value_json[‘soc’] <= ‘49’ and value_json[‘soc’] > ‘40’ and states.sensor.battery_power_2.state >= ‘0’ %} mdi:battery40 {% elif value_json[‘soc’] <= ‘39’ and value_json[‘soc’] > ‘30’ and states.sensor.battery_power_2.state >= ‘0’ %} mdi:battery30 {% elif value_json[‘soc’] <= ‘29’ and value_json[‘soc’] > ‘20’ and states.sensor.battery_power_2.state >= ‘0’ %} mdi:battery20 {% elif value_json[‘soc’] <= ‘19’ and value_json[‘soc’] > ‘10’ and states.sensor.battery_power_2.state >= ‘0’ %} mdi:battery10 {% elif value_json[‘soc’] <= ‘09’ and value_json[‘soc’] > ‘06’ and states.sensor.battery_power_2.state >= ‘0’ %} mdi:battery10 {% elif value_json[‘soc’] <= ‘5’ and value_json[‘soc’] > ‘0’ and states.sensor.battery_power_2.state >= ‘0’ %} mdi:batteryoutline {% elif value_json[‘soc’] <= ‘100’ and value_json[‘soc’] > ‘96’ and states.sensor.battery_power_2.state < ‘0’ %} mdi:flash:battery-charging-100 {% elif value_json[‘soc’] <= ‘95’ and value_json[‘soc’] > ‘90’ and states.sensor.battery_power_2.state < ‘0’ %} mdi:battery-charging-90 {% elif value_json[‘soc’] <= ‘89’ and value_json[‘soc’] > ‘80’ and states.sensor.battery_power_2.state < ‘0’ %} mdi:battery-charging-80 {% elif value_json[‘soc’] <= ‘79’ and value_json[‘soc’] > ‘70’ and states.sensor.battery_power_2.state < ‘0’ %} mdi:battery-charging-70 {% elif value_json[‘soc’] <= ‘69’ and value_json[‘soc’] > ‘60’ and states.sensor.battery_power_2.state < ‘0’ %} mdi:battery-charging-60 {% elif value_json[‘soc’] <= ‘59’ and value_json[‘soc’] > ‘50’ and states.sensor.battery_power_2.state < ‘0’ %} mdi:battery-charging-50 {% elif value_json[‘soc’] <= ‘49’ and value_json[‘soc’] > ‘40’ and states.sensor.battery_power_2.state < ‘0’ %} mdi:battery-charging-40 {% elif value_json[‘soc’] <= ‘39’ and value_json[‘soc’] > ‘30’ and states.sensor.battery_power_2.state < ‘0’ %} mdi:battery-charging-30 {% elif value_json[‘soc’] <= ‘29’ and value_json[‘soc’] > ‘20’ and states.sensor.battery_power_2.state < ‘0’ %} mdi:battery-charging-20 {% elif value_json[‘soc’] <= ‘19’ and value_json[‘soc’] > ‘10’ and states.sensor.battery_power_2.state < ‘0’ %} mdi:battery-charging-10 {% elif value_json[‘soc’] <= ‘09’ and value_json[‘soc’] > ‘06’ and states.sensor.battery_power_2.state < ‘0’ %} mdi:battery-charging-10 {% elif value_json[‘soc’] <= ‘5’ and value_json[‘soc’] > ‘0’ and states.sensor.battery_power_2.state < ‘0’ %} mdi:battery-charging-outline {%- endif %}”, ‘unique_id’: ‘G345-I-BattSoC-1’, ‘device_class’: ‘power’, ‘device’: {‘identifiers’: [‘G345-I-BattSoC_1’], ‘manufacturer’: ‘GivEnergy’}, ‘platform’: ‘mqtt’},)
When pushing JSON icon, I’ve tried the HA sensor state data, my most recent attempt has been the value_json node, and I’ve tried escape characters, without escape characters, swapping the ’ for a " …
Here’s the JSON string I’m passing in MQTT/config:
"name": "Battery State of Charge (GE)",
"stat_t": "givenergy/cloud/summary",
"avty_t": "givenergy/cloud/status",
"pl_avail": "Online",
"pl_not_avail": "Offline",
"json_attr_t": "givenergy/cloud/summary",
"unit_of_meas": "%",
"val_tpl": "{{value_json['soc']}}",
"icon_template": "{%- if value_json[\"soc\"] <= \"100\" and value_json[\"soc\"] > \"96\" and states.sensor.battery_power_2.state >= \"0\" %} mdi:battery {% elif value_json[\"soc\"] <= \"95\" and value_json[\"soc\"] > \"90\" and states.sensor.battery_power_2.state >= \"0\" %} mdi:battery-90 {% elif value_json[\"soc\"] <= \"89\" and value_json[\"soc\"] > \"80\" and states.sensor.battery_power_2.state >= \"0\" %} mdI:battery80 {% elif value_json[\"soc\"] <= \"79\" and value_json[\"soc\"] > \"70\" and states.sensor.battery_power_2.state >= \"0\" %} mdi:battery70 {% elif value_json[\"soc\"] <= \"69\" and value_json[\"soc\"] > \"60\" and states.sensor.battery_power_2.state >= \"0\" %} mdi:battery60 {% elif value_json[\"soc\"] <= \"59\" and value_json[\"soc\"] > \"50\" and states.sensor.battery_power_2.state >= \"0\" %} mdi:battery50 {% elif value_json[\"soc\"] <= \"49\" and value_json[\"soc\"] > \"40\" and states.sensor.battery_power_2.state >= \"0\" %} mdi:battery40 {% elif value_json[\"soc\"] <= \"39\" and value_json[\"soc\"] > \"30\" and states.sensor.battery_power_2.state >= \"0\" %} mdi:battery30 {% elif value_json[\"soc\"] <= \"29\" and value_json[\"soc\"] > \"20\" and states.sensor.battery_power_2.state >= \"0\" %} mdi:battery20 {% elif value_json[\"soc\"] <= \"19\" and value_json[\"soc\"] > \"10\" and states.sensor.battery_power_2.state >= \"0\" %} mdi:battery10 {% elif value_json[\"soc\"] <= \"09\" and value_json[\"soc\"] > \"06\" and states.sensor.battery_power_2.state >= \"0\" %} mdi:battery10 {% elif value_json[\"soc\"] <= \"5\" and value_json[\"soc\"] > \"0\" and states.sensor.battery_power_2.state >= \"0\" %} mdi:batteryoutline {% elif value_json[\"soc\"] <= \"100\" and value_json[\"soc\"] > \"96\" and states.sensor.battery_power_2.state < \"0\" %} mdi:flash:battery-charging-100 {% elif value_json[\"soc\"] <= \"95\" and value_json[\"soc\"] > \"90\" and states.sensor.battery_power_2.state < \"0\" %} mdi:battery-charging-90 {% elif value_json[\"soc\"] <= \"89\" and value_json[\"soc\"] > \"80\" and states.sensor.battery_power_2.state < \"0\" %} mdi:battery-charging-80 {% elif value_json[\"soc\"] <= \"79\" and value_json[\"soc\"] > \"70\" and states.sensor.battery_power_2.state < \"0\" %} mdi:battery-charging-70 {% elif value_json[\"soc\"] <= \"69\" and value_json[\"soc\"] > \"60\" and states.sensor.battery_power_2.state < \"0\" %} mdi:battery-charging-60 {% elif value_json[\"soc\"] <= \"59\" and value_json[\"soc\"] > \"50\" and states.sensor.battery_power_2.state < \"0\" %} mdi:battery-charging-50 {% elif value_json[\"soc\"] <= \"49\" and value_json[\"soc\"] > \"40\" and states.sensor.battery_power_2.state < \"0\" %} mdi:battery-charging-40 {% elif value_json[\"soc\"] <= \"39\" and value_json[\"soc\"] > \"30\" and states.sensor.battery_power_2.state < \"0\" %} mdi:battery-charging-30 {% elif value_json[\"soc\"] <= \"29\" and value_json[\"soc\"] > \"20\" and states.sensor.battery_power_2.state < \"0\" %} mdi:battery-charging-20 {% elif value_json[\"soc\"] <= \"19\" and value_json[\"soc\"] > \"10\" and states.sensor.battery_power_2.state < \"0\" %} mdi:battery-charging-10 {% elif value_json[\"soc\"] <= \"09\" and value_json[\"soc\"] > \"06\" and states.sensor.battery_power_2.state < \"0\" %} mdi:battery-charging-10 {% elif value_json[\"soc\"] <= \"5\" and value_json[\"soc\"] > \"0\" and states.sensor.battery_power_2.state < \"0\" %} mdi:battery-charging-outline {%- endif %}",
"uniq_id": "I-BattSoC-1",
"device_class": "battery",
"dev": {
"ids": [
"I-BattSoC_1"
"mf": "GivEnergy"
Hoping someone can tell me what I’m doing wrong, or if it’s unsupported (in which case this post is a lie).
