Hi!
I am implemeting a device compatible with HASS MQTT discovery feature.
During my experiments I have faced unexpected behaviour: the availability and status topics subscriptions for autodiscovered devices do not receive any messages.
I have added a new device using the following message to topic:
homeassistant/switch/dev1/config
"~":"b/office/dev1",
"uniq_id":"dev1",
"cmd_t":"~/set",
"stat_t":"~/state",
"avty_t":"~/available",
"dev":{
"ids":"b_esp32",
"name":"B",
"mf":"B",
"mdl":"153-e",
"sw":"1.0",
"sn":"ea3350945afc",
"hw":"B5"
This creates a new device with an entity and correct subscriptions.
Then I post the messages:
b/office/dev1/available
online
and
b/office/dev1/state
OFF
But neither of the listed Subsribed topics receives the incoming messages.
The home-assistant.log
says:
2024-08-09 14:21:48.705 DEBUG (MainThread) [homeassistant.components.mqtt.client] Received message on homeassistant/switch/dev1/config (qos=0): b'{\r\n "~":"b/office/dev1",\r\n "uniq_id":"dev1",\r\n "cmd_t":"~/set",\r\n "stat_t":"~/state",\r\n "avty_t":"~/available",\r\n "dev":{\r\n "ids":"b_esp32",\r\n "name":"B",\r\n "mf":"B",\r\n "mdl":"153-e",\r\n "sw":"1.0",\r\n "sn":"ea3350945afc",\r\n "hw":"B5"\r\n }\r\n}'
2024-08-09 14:21:48.706 DEBUG (MainThread) [homeassistant.components.mqtt.discovery] Process discovery payload {'device': {'name': 'B', 'model': '153-e', 'hw_version': 'B5', 'serial_number': 'ea3350945afc', 'identifiers': 'b_esp32', 'manufacturer': 'B', 'sw_version': '1.0'}, 'unique_id': 'dev1', 'command_topic': 'b/office/dev1/set', 'availability_topic': 'b/office/dev1/available', 'state_topic': 'b/office/dev1/state', 'platform': 'mqtt'}
2024-08-09 14:21:48.706 INFO (MainThread) [homeassistant.components.mqtt.discovery] Found new component: switch dev1
2024-08-09 14:21:48.707 DEBUG (MainThread) [homeassistant.components.mqtt.discovery] Pending discovery for ('switch', 'dev1'): deque([])
2024-08-09 14:21:48.810 DEBUG (MainThread) [homeassistant.components.mqtt.client] t144cc11.ala.eu-central-1.emqxsl.com: register write 15
2024-08-09 14:21:48.810 DEBUG (MainThread) [homeassistant.components.mqtt.client] Subscribing with mid: 24 to topics with qos: [('b/office/dev1/available', 0), ('b/office/dev1/state', 0)]
2024-08-09 14:21:48.811 DEBUG (MainThread) [homeassistant.components.mqtt.client] t144cc11.ala.eu-central-1.emqxsl.com: unregister write 15
2024-08-09 14:22:39.882 DEBUG (MainThread) [homeassistant.components.mqtt.client] t144cc11.ala.eu-central-1.emqxsl.com: register write 15
2024-08-09 14:22:39.887 DEBUG (MainThread) [homeassistant.components.mqtt.client] t144cc11.ala.eu-central-1.emqxsl.com: unregister write 15
register write 15
and unregister write 15
are the only records I get in home-assistant.log
when I send messages to the availability or state topics.
Any ideas how to find out why HASS doesn’t receive the messages though everything looks like it should?
