I’m trying to use MQTT discovery to set up a device with 6 entities. I had this working in 2022, but when I finally got around to physically installing the device, HomeAssistant wasn’t receiving data from it even though the data was visible using MQTT Explorer.
Poking around, I found this error in my logs:
2024-07-28 17:39:57.675 ERROR (MainThread) [homeassistant.components.mqtt.mixins] Error 'value should be a string for dictionary value @ data['device']['name']' when processing MQTT discovery message topic: 'homeassistant/sensor/omronT/config', message: '{'device': {'identifiers': ['ff1'], 'name': ['furn']}, 'force_update': True, 'unit_of_measurement': '°F', 'state_topic': 'furn/state', 'value_template': '{{ value_json.temperatureO }}', 'unique_id': 'furn/omronT', 'name': 'Temperature', 'device_class': 'temperature', 'platform': 'mqtt'}'
2024-07-28 17:39:57.684 ERROR (MainThread) [homeassistant.components.mqtt.mixins] Error 'value should be a string for dictionary value @ data['device']['name']' when processing MQTT discovery message topic: 'homeassistant/sensor/omronP/config', message: '{'device': {'identifiers': ['ff1'], 'name': ['furn']}, 'force_update': True, 'unit_of_measurement': 'Pa', 'state_topic': 'furn/state', 'value_template': '{{ value_json.pressure }}', 'unique_id': 'furn/omronP', 'name': 'Pressure', 'device_class': 'pressure', 'platform': 'mqtt'}'
2024-07-28 17:39:57.694 ERROR (MainThread) [homeassistant.components.mqtt.mixins] Error 'value should be a string for dictionary value @ data['device']['name']' when processing MQTT discovery message topic: 'homeassistant/sensor/dhtT/config', message: '{'device': {'identifiers': ['ff1'], 'name': ['furn']}, 'force_update': True, 'unit_of_measurement': '°F', 'state_topic': 'furn/state', 'value_template': '{{ value_json.temperatureD }}', 'unique_id': 'furn/dhtT', 'name': 'Temperature', 'device_class': 'temperature', 'platform': 'mqtt'}'
2024-07-28 17:39:57.707 ERROR (MainThread) [homeassistant.components.mqtt.mixins] Error 'value should be a string for dictionary value @ data['device']['name']' when processing MQTT discovery message topic: 'homeassistant/sensor/dhtH/config', message: '{'device': {'identifiers': ['ff1'], 'name': ['furn']}, 'force_update': True, 'unit_of_measurement': '%', 'state_topic': 'furn/state', 'value_template': '{{ value_json.humidity }}', 'unique_id': 'furn/dhtH', 'name': 'Humidity', 'device_class': 'humidity', 'platform': 'mqtt'}'
2024-07-28 17:39:57.719 ERROR (MainThread) [homeassistant.components.mqtt.mixins] Error 'value should be a string for dictionary value @ data['device']['name']' when processing MQTT discovery message topic: 'homeassistant/sensor/dhtI/config', message: '{'device': {'identifiers': ['ff1'], 'name': ['furn']}, 'force_update': True, 'unit_of_measurement': '°F', 'state_topic': 'furn/state', 'value_template': '{{ value_json.heatindex }}', 'unique_id': 'furn/dhtI', 'name': 'Heat Index', 'device_class': 'temperature', 'platform': 'mqtt'}'
2024-07-28 17:39:57.731 ERROR (MainThread) [homeassistant.components.mqtt.mixins] Error 'value should be a string for dictionary value @ data['device']['name']' when processing MQTT discovery message topic: 'homeassistant/sensor/airWF/config', message: '{'device': {'identifiers': ['ff1'], 'name': ['furn']}, 'force_update': True, 'unit_of_measurement': 'dBm', 'state_topic': 'furn/state', 'value_template': '{{ value_json.wifi }}', 'unique_id': 'furn/airWF', 'name': 'Wifi Strength', 'device_class': 'signal_strength', 'platform': 'mqtt'}'
For reference, here is the retained message for one of the sensors, homeassistant/sensor/omronP/config:
"name": "Pressure",
"stat_t": "furn/state",
"unit_of_meas": "Pa",
"dev_cla": "pressure",
"frc_upd": true,
"val_tpl": "{{ value_json.pressure }}",
"uniq_id": "furn/omronP",
"dev": {
"ids": [
"ff1"
"name": [
"furn"
And my setup in MQTT Explorer
What’s gone wrong? Has something changed since I created this in 2022?
I’m expecting a device with 6 sensors entities attached.
