Hello.
Manually I can create customize attribute related to my sensor (sensor has been created by MQTT discovery msg) in configuration.yaml like below:
homeassistant:
customize:
sensor.heatmeter_kamheat_co_4_power_kw: ##<--- you forgot the : here
notes: my some notes here
And next I can found the attribute eg. here:
or here:
Because I have a lots MQTT devices and much more entities then I want to achieve similar solution (assign attributes to entities) but exploited MQTT discovery msg. For this I found below documentation with section JSON_ATTRIBUTES_TOPIC_CONFIGURATION:
To do this I create below discovery MQTT msg (show only config payload JSON part below)
"json_attributes_topic": "homeassistant/sensor/CWU_2/state",
"json_attributes_template": "{{ value_json.meter }}",
"name": "historical_total_m3",
"state_topic": "homeassistant/sensor/CWU_2/state",
"unique_id": "historical_total_m3_00348454_aptmbusna.xmq",
"expire_after": "370",
"value_template": "{{ value_json.historical_total_m3 }}",
"unit_of_measurement": "m³",
"state_class": "TOTAL_INCREASING",
"device_class": "VOLUME",
"device": {
"serial_number": "00348454",
"hw_version": "n/a",
"manufacturer": "Apator",
"identifiers": "00348454",
"name": " CWU_2"
"origin": {
"name": "wmbusmeters",
"support_url": "https://github.com/wmbusmeters/wmbusmeters/",
"sw_version": "wmbusmeters: 1.17.1-29-g3af7a4c 3af7a4c8a881c10498f1e14d950d4e502ab2fa7e"
However cannot found attribute assign to the sensor:
My question is can be a problem that json_attributes_topic
and state_topic
are the same (I have also separated discovery msg for meter
but sensor is disable in HA) ? How to resolve the problem? Choose meter
for a test only as mentioned related entity is disabled in HA.
Additional in Home Assistant Core logs no errors found related to sensor historical_total_m3
Below example topic homeassistant/sensor/CWU_2/state
JSON
media: water
meter: aptmbusna
current_volume_flow_lh: 0
historical_meter_date: '2004-07-01'
historical_total_m3: 0.056
meter_datetime: 2024-10-24 11:27
operating_battery_d: 1696
total_volume_m3: 0.47
events_active_type: OK
events_permanent_type: >-
P_CLOCK_HAND_ERROR P_DETECTION_WITHOUT_CHANGES P_DETECTOR_ERROR
P_M-BUS_DISCONNECTED P_PROCESSOR_RESET_DETECTED P_STRONG_LIGHT_DETECTED
fabrication_no: '00348454'
optical_diagnostic: '00010404'
oscilator_diagnostic: '0000'
power_supply_diagnostic: B40CBB
timestamp: '2024-10-24T09:27:03Z'
device: SERIAL_1
rssi_dbm: 0
