I have a problem with MQTT discovery.
I would like to monitor the state of my heating/cooling system. The system is not a mainstream one, but I have connected to it via Modbus using a gateway.
Formerly (before using Home Assistant) I used NodeRed to read out the data, it is working perfectly at the moment.
I created some MQTT Discovery configuration topics (mostly for the temperature sensors) and publish data from NodeRed via MQTT to Home Assistant.
I can see the temperature sensors, but I cannot get a new sensor discovered (generic one or binary sensor) to see other states of my system.
The config and state topics are published (I see them in MQTT Explorer), but they are not discovered by Home Assistant.
Here is the name of the not working configuration topic and its contents:
homeassistant/sensor/energiakulcs/funkciomod2/config
{"device_class":"None",
"name":"Energiakulcs Hőszivattyú",
"state_topic":"homeassistant/sensor/energiakulcs/funkciomod2/state",
"unique_id":"EK_18_Funkciomod2",
"json_attributes_topic":"energiakulcs",
"json_attributes_template":"{{ value_json | tojson }}",
"device":{"identifiers":["EnergiakulcsGephaz"],
"name":"Energiakulcs2017",
"model":"Energetikai központ",
"manufacturer":"Kardos Labor"}}
28
And here is a working one:
homeassistant/sensor/energiakulcs/kaloriferkorr_homerseklet/config
{"device_class":"temperature",
"name":"Energiakulcs kalorifer korrigált hőmérséklet",
"state_topic":"homeassistant/sensor/energiakulcs/kaloriferkorr_homerseklet/state",
"unit_of_measurement":"°C",
"value_template":"{{ value_json.temperature}}",
"unique_id":"EK_18_KaloriferKorrT",
{"name":"Kalorifer korrigált hőmérséklet",
"temperature":"28.9"}
I didn’t find much in the forum on MQTT Discovery. I have read the documentation, but I am also new on Home Assistant.
Could somebody please point me in the right direction?
