I am trying to add a Tradfri zigbee bulb to homeassistant via zigbee2mqtt. For some reason, the main “light” entity is not being discovered. The device does exists, there is just no entity for it.
This is what is being sent to homeassistant/light/0x8c6fb9fffe1b47ab/light/config
"availability": [
"topic": "zigbee2mqtt/bridge/state"
"brightness": true,
"brightness_scale": 254,
"color_mode": true,
"command_topic": "zigbee2mqtt/living_room_ceiling_light/set",
"device": {
"identifiers": [
"zigbee2mqtt_0x8c6fb9fffe1b47ab"
"manufacturer": "IKEA",
"model": "TRADFRI LED bulb E27 1055 lumen, dimmable, white spectrum (LED2201G8)",
"name": "living_room_ceiling_light",
"sw_version": "2.4.5"
"effect": true,
"effect_list": [
"blink",
"breathe",
"okay",
"channel_change",
"finish_effect",
"stop_effect"
"json_attributes_topic": "zigbee2mqtt/living_room_ceiling_light",
"max_mireds": 454,
"min_mireds": 250,
"name": null,
"object_id": "living_room_ceiling_light",
"origin": {
"name": "Zigbee2MQTT",
"sw": "1.33.2",
"url": "https://www.zigbee2mqtt.io"
"schema": "json",
"state_topic": "zigbee2mqtt/living_room_ceiling_light",
"supported_color_modes": [
"xy",
"color_temp"
"unique_id": "0x8c6fb9fffe1b47ab_light_zigbee2mqtt"
Any help is appreciated
