Is there a way to change the order that the entities are displayed in the device page? Lets say: Change the position fo the two entities shown in the image below.
Rename the last one to 1.1 Usuario
and rename the first 1.1...
to 1.4...
I would like to remove those number, that was what I was trying to do… But seems like there is no other option I will have to leave then there.
Thanks!
On the device over view page the entities are grouped and then sorted by name.
You can create a dashboard card to choose the entities you want and have them in the order you like
Hello, is there a solution in the meantime? I have the same requirement.
I haven’t found one, I had to leave the numbers to place entities in the order that I wanted.
